Need help with engine seals/gaskets
Old Jul 18, 2009 | 07:32 PM
huttler's Avatar
huttler
Default Need help with engine seals/gaskets
I'm doing a heads/cam swap soon, I was wondering what the best brand/material there is available for gaskets and seals. Napa online has a few options, but they don't go into any detail (see below). Also, will I have to change the oil pan gasket?
- PermaDry Molded Rubber Gasket
- Viton
- PTFE Rubber
GMpartshouse has two options for the front cover gasket, that very greatly in price. Will either of these work for a '99?
- Front cover gasket, corvette - 5.7l - 97-04 $19.27
- Front cover gasket, corvette - 5.7l - 97-02 $7.24
Thanks for the help
Old Jul 18, 2009 | 08:02 PM
vettesrnice's Avatar
vettesrnice
i used the front cover and valve covers over and over no leaks. exaust for heads reuse too. you need new head bolts.
