As some of you have followed, I recently had a coolant reservoir go bad on me on the highway and I ended up running the car in a "reduce power mode" for about a mile to get a tow. Well, the reservoir came in today and I replaced it. The car started right up, added the coolant, change the oil (no coolant issue there either) and the thermostat never opened up so the car got up to 240 before I shut her down. I am thinking that my thermostat is shot.
The car does not have any leaks and no knocking, so hopefully a new thermostat fixes it. I am posting up in TECH to see what others think.
At 240 deg, both fans should have been operating, was that the case, was there warm air coming out from behind them? As previously stated, verify that the cooling system is filled to capacity.
Before spending the money on a new t-stat, you can check it's operation by placing in a pan with water while on the stove, heat it and see whether it opens. I believe the stock t-stat opens around 195 deg F. I use and infrared thermometer to check the temperature of the water; a meat thermometer would probably work as long at the temperature range goes sufficiently high.
Every thermostat I've ever suspected of not opening I've tested this way, as a matter of fact, I don't recall ever having one not open.
# Fill the system through the surge tank opening.
# Fill half the capacity of the system with 100 percent DEX-COOL® coolant.
# Slowly add clean drinkable water to the system until the level reaches to the base of the neck.
# Start the engine.
# Idle engine for 1 minute.
# Install surge tank cap.
# Cycle the RPM, idle to 3000 in 30 second intervals until engine coolant reaches 99°C (210°F).
# Shut off the engine.
# Refer to step 3 above to remove the surge tank cap.
# Start the engine.
# Idle engine for 1 minute and fill surge tank to 1/2 inch above COLD FULL mark on the radiator surge tank.
# Install the surge tank cap.
# Top off coolant as necessary, 1/2 inch above FULL COLD mark on the radiator surge tank.
# Rinse away any excess coolant from the engine and the compartment.
# Inspect the concentration of the coolant.
# Start the engine.
# Start the engine.
Also, its probably a good idea to change the T-stat anyway.
