I am so P@##$d
Old Jul 21, 2009 | 11:57 PM
pgj98m3's Avatar
pgj98m3
Default I am so P@##$d
I was planning to leave Thursday morning to drive from Vancouver to Edmonton with my daughter for the Indy ....today at 5 pm as I started home I got the Pull Key Wait 10 Seconds message followed by Check Column Lock....now I know this is a common problem but the G-D dealer just did the bypass less then a month ago...
The vette is now at the dealer and tomorrow my rant will continue with the service rep. Last month it took them 2 weeks to get the relay from back East
Old Jul 22, 2009 | 12:05 AM
txFRC's Avatar
txFRC
i dont understand why anyone goes to the dealer to get it fixed, when theres just as many stories of it happening again after they 'fix' it. all you have to do is get the 20$ clb bypass box and be DONE with it FOREVER! takes 30min!
Old Jul 22, 2009 | 12:15 AM
Trpblk04's Avatar
Trpblk04
As much as this forum has discussed this I have no ideal either..
Old Jul 22, 2009 | 12:53 AM
intoc6s's Avatar
intoc6s
I was soooo glad that the previous owner already took care of this!! Its such a PIA for alot of people and it s a matter of time in all C5s.
Old Jul 22, 2009 | 01:02 AM
pgj98m3's Avatar
pgj98m3
Well...the first trip to the dealer was just being lazy...that was 2 months ago. The car was there to get the rear diff seal replaced when the Column Lock was triggered. Three weeks later I got the car back just before I went away for 3 weeks I'm back 2 weeks before I'm away for essentially the rest of the summer....so when I get a chance I will do the bypass discuused so much on this board in the mean-time my car wouldn't move....so unless someone was going to deliver the bypass to a mall parking lot I needed to get the car fixed. I did expect the dealer fix to last more then 1 month...silly me
Oh...I bought this car from a forum member and brought it up to Canada last year...no problems till now
Old Jul 22, 2009 | 02:48 AM
clayton1's Avatar
clayton1
Banned Scam/Spammer
GEt the CLB and save yourself the headaches.
It may be a bit more than $20 for us Canucks but still must be done. (ITs the UPS bs that got me)
Old Jul 22, 2009 | 10:26 AM
itzza427's Avatar
itzza427
Closer to $50 U.S.,,,but it's about the only viable option!!Must be Murphy's law these things NEVER happen at a convenient time Mine was a minor pain in the the a$$ when it happened,,but a pain none the less!!
Old Jul 22, 2009 | 10:30 AM
pgj98m3's Avatar
pgj98m3
Originally Posted by 8VETTE7
Well if you don't get it fixed right, now, (and the dealer can't do that) it will leave you stranded again somewhere between now and the end of the summer. CLB OR having the fuel shutoff reprogrammed to 255 are the only two solutions that are long lasting. Dealer solution is pure and simple theft of your money............
Since getting the CLB to Vancouver within 24 hrs is unlikely I will look at getting the fuel shutoof reprogrammed if I can find someplace to do it today or early tomorrow. The dealer has not charged me for the Column Lock fix as it is a recall issue
Old Jul 22, 2009 | 10:36 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Sorry to hear you are having the same problem as just about everyone with a C5. It stinks to have things happen right before a trip. Did you try clearing all the codes to see if this will let you drive it?
Old Jul 22, 2009 | 11:47 AM
pgj98m3's Avatar
pgj98m3
To get the fuel shutoff speed reprogrammed you need to find a tuner with either HP Tuners of EFI Live tuning software. They are the ONLY two tools that have the capability to set the shutoff value in the PCM. It takes the tuner 5 minutes to do the reset..................
Thanks...this board is great for helpping out someone in need
Old Jul 22, 2009 | 05:02 PM
pgj98m3's Avatar
pgj98m3
To update...turns out the dealer had just tried to reprogram the Column Lock...luckily someone else had their vette in and the dealer had the GM harness brought in. That person didn't need their vette back right away and generously let them install the harness in my car. I know, I know, its not a permanent fix...I will do either the retune or the aftermarket bypass when I get back from my trip.....and I won't ask for any sympathy if the Check Column Lock triggers bewtween Vancouver and Edmonton
Old Jul 22, 2009 | 06:34 PM
Pro Street's Avatar
Pro Street
Good Luck !!! I bet it will be fine and you have a good time.
Old Jul 22, 2009 | 07:31 PM
Old Rotor Head's Avatar
Old Rotor Head
To I am so P@##$d
