WSW Problem
Old Jul 22, 2009 | 11:50 PM
BlueSkunk952's Avatar
BlueSkunk952
Default WSW Problem
Last weekend I put about 700 miles on the car. For about the last 50 miles, the windshield wipers decided to show me they worked every minute or so. They eventually stayed on permanently. I realized this didn't look cool , since it was not raining, so I stopped and pulled the fuse. I will diagnose the problem this weekend. I think the wiper switch may be defective. I wondered if anyone else here has experienced this phenomenon. This is a 2004 Z06 with just 16,000 miles on it. I will let you all know what I find. I guess it is better to have them constantly working than never working at all.
Speed Safely, Don.
Old Jul 23, 2009 | 11:45 AM
BigGun's Avatar
BigGun
Speed Safely, Don.
Could also be the motor. Have you, do you , check the drain udders to make sure they are not clogged. Check this post.
http://forums.corvetteforum.com/c5-t...mlins-wtf.html
Old Jul 23, 2009 | 11:58 AM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
Disconnect the switch connector, replace the fuse. If the wipers are still always on it's most likely the motor or motor circuit. If they are off, it's most likely the switch or switch circuit.
Old Jul 23, 2009 | 09:45 PM
BlueSkunk952
Thanks for the tip on the wiper motor problem. I will check that first. I had not been aware of the udder fix. I learn something new every time I use this forum. I will keep you posted. Thanks again, Don.
Old Jul 23, 2009 | 11:00 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You most likley have clogged cowl drain udders. The water in the well is shorting out the control module and causing it to loose its mind. If you catch it early enough, you may be able to save it. I recommend disassembling it and spraying the module out with WD-40.
BC
Old Jul 24, 2009 | 08:29 AM
BlueSkunk952
This problem did begin after a very heavy rainfall. Hopefully, I can clear the drains and dry out the module and everything will be fine.
Old Jul 26, 2009 | 12:35 AM
BlueSkunk952
Today I removed the WSW Module and cleaned out the drains. I found a lot of debris in there. I removed the module cover, sprayed a little WD-40 inside it, and resealed the case. The module was actually damp and it has not been in the rain since last week. After reassembly I took the car for a ride and everything is back to normal now.
Thanks for all the helful hints with this problem. You guys are great!
Saved me a bunch of time and money.
Here's some pics.....
To WSW Problem
