Headlight warning bell not working
Old Jul 23, 2009 | 06:16 PM
corvette Mark's Avatar
corvette Mark
Default Headlight warning bell not working
99 coupe. When I leave my headlights on and remove the key my warning bell is not working. It also does not work to remind you to close door with key in ignition. Has anyone else had this problem?? Where is the bell located??
Old Jul 23, 2009 | 09:49 PM
byronhunter's Avatar
byronhunter
I think the audible warning comes from the IPC. Check for diagnostic codes and post them if you don't have a Service Manual.
Old Jul 24, 2009 | 12:49 AM
DeeGee's Avatar
DeeGee
The funny thing is I find the warning bell a total PITA. I wish I could fix mine so it works like yours
byronhunter is correct. The warning chime is a function built into the IPC but its controlled by the BCM. As you can see the troubleshooting guide tries to isolate whether the fault is with one of the functions that is being monitored or whether its a control failure. If its the latter the solution is a replacement BCM. I'm sure I wouldn't buy a new BCM to bring back that annoying "bong bong".
Chime Inoperative
Step
Action
Yes
No
Schematic Reference: Audible Warnings Schematics
1. Did you perform the Audible Warning Diagnostic System Check?
Go to Step 2
Go to Diagnostic System Check - Audible Warnings
2.
1. Turn ON the ignition.
2. Buckle the driver's seat belt.
Is the fasten seat belt indicator inoperative?
Go to Seat Belt Indicator Circuit Malfunction in Seat Belts
Go to Step 3
3. Turn the headlamps on.
Are the headlamps on?
Go to Step 4
Go to Headlamps Inoperative - Low and High Beams in Lighting Systems
4. Open the driver's door.
Does the DIC display DOOR AJAR?
Go to Step 5
Go to Door Ajar Indicator Inoperative in Doors
5. Important
Program the replacement BCM.
Replace the BCM. Refer to Body Control Module Replacement in Body Control System.
Did you complete the replacement?
Go to Step 6
6. Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 2
Document ID# 662524
2002 Chevrolet Corvette
Heres the schematic if you want to dig further. Its controlled by fuse #19 in the footwell
Old Jul 27, 2009 | 09:12 AM
corvette Mark
Is the IPC the instrument cluster??
No trouble codes....
Chime Inoperative
Step
Action
Yes
No
Go to Step 2
2.
Go to Step 3
Go to Step 4
Go to Step 5
5. Important
Go to Step 6
System OK
Go to Step 2
Document ID# 662524
Awesome info!! I will get to this asap and let you know what I find.
Old Jul 27, 2009 | 10:05 AM
jedblanks's Avatar
jedblanks
My original 97 cluster never chimed either (I actually left the parking lights on the first week I had the car). Once I upgraded to the HUD and an 02 cluster, they started working (actually startled me). Has to be in the cluster.
Old Jul 27, 2009 | 02:44 PM
corvette Mark
That is what I'm afraid of. I do not want to get into changing cluster. I'm thinking of selling the car and I want to fix everything within reason and this is not anything I want to mess with.
BTW how much did you pay for a cluster and how did you correct the miles??
To Headlight warning bell not working
