P0300 Code pulled, looking for advice!
Old Jul 24, 2009 | 05:08 PM
xboxexpert's Avatar
xboxexpert
Default P0300 Code pulled, looking for advice!
I was drive a few days ago and it felt like I had a cam in the car....boom Service Engine light flickers and I pull a P0300 code. Doing some research on these forums I felt like I needed to replace the spark plugs...while I put some NGK's and some new GM Hotwire Wires I'm still getting the same issue. I then took it to my guy for injector cleaning. Afterwhich It still does the same thing. I'm guessing my MSD Ignition coils are going...is this the next think I should fix. Should I just go back to stock GM's? If so does anyone have any new or slightly used set of 8 I'm located in North Newark NJ.
Old Jul 24, 2009 | 05:25 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
Is the P300 the only code present? If it is, then you've got to look at what would cause a mulit-cylinder random misfire. Things that would come to mind would be weak fuel pressure, MAF, camshaft position sensor or crank position sensor, and oxygen sensors getting lazy. Best bet is going to be to get it on a laptop for some data logging if you've got anyone local that could help.
Old Jul 24, 2009 | 05:30 PM
xboxexpert's Avatar
xboxexpert
Thats the only code present. Wouldnt O2's shoot a code out, so would hte MAF and the other sensors...Its sparatic which leads me to believe its a coil thats dying.
Old Jul 24, 2009 | 05:50 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
P0300 doesn't have to mean "multiple" misfires.
In these cars it is a catch-all code for ANY misfire detected....the DIC diagnostics do not have the capability to display a "P0304" (for example - would indicate cyl 4 is the one misfiring)....but better scan tools do have the capability to display individual cylinder misfires, which can help a great deal in troubleshooting.
If the misfire is not there consistently, then it definitely seems more ignition related (as opposed to other common causes like fuel delivery or broken valve spring), and in that case I would get it to someone with a real scan tool, and hopefully identify which cylinder may be causing it.
Old Jul 24, 2009 | 05:59 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
Really??? The DIC can't display P0301 through P0308?? WTF man? In that case, my suggestion would be go to Advance Auto Parts, Auto Zone, whomever you've got local and have them put their scanner on it and see if it's truly a P0300 or a single cylinder misfire being shown.
Good call Y2K, taught me something today.
Old Jul 24, 2009 | 06:20 PM
Y2Kvert4me's Avatar
Y2Kvert4me
St. Jude Donor '03
We should feel fortunate we have the capability to so easily check codes w/o a scanner, period.
The list of possible codes that can be reported/displayed goes from P0300 to P0325....nothing in between.
Old Jul 24, 2009 | 07:15 PM
dougbfresh's Avatar
dougbfresh
Random misfire is a P300, P30X will show a SPECIFIC cylinder.
Old Jul 24, 2009 | 07:45 PM
crainholio's Avatar
crainholio
Fellow Jerseyan in distress, PM sent. Hope I can help.
Old Jul 24, 2009 | 08:18 PM
xboxexpert's Avatar
xboxexpert
I got pissed off a few hours ago and started reading about MSD's on these vette's. I've replacated the issue and it seems to be a coil pack. I've called CarTek and had them order me Stock GM coil packs...I'm going to grab them and slap them in I'll update you at a later date.
Old Jul 24, 2009 | 08:21 PM
xboxexpert's Avatar
xboxexpert
UPDATE: I sold my MSD's labeled broken on the bay for 380 bucks. CarTek charged me 480 for all coil packs...I'd say 100 bucks isnt bad for NEW Stock Coils....Woohoo can't wait, with all the new wires I put in and the injector cleaning this puppy should idle perfectly. After I'm done and over with I'm gonna get a nice *** tune!
Old Jul 24, 2009 | 11:11 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Waiting for the up-date day...
BC
Old Jul 25, 2009 | 03:56 AM
bullitt4110's Avatar
bullitt4110
Those MSD's are well known for going bad, another time the 0300 code comes up is with a cam.
Old Jul 25, 2009 | 08:48 AM
Chevy Guy's Avatar
Chevy Guy
Yup, the MSD's look nice but nothing beats the OE coils for most applications.
Old Aug 3, 2009 | 12:44 AM
xboxexpert's Avatar
xboxexpert
Okay tested it for a few days, worked perfectly changed coils out to stock
To P0300 Code pulled, looking for advice!
