trouble code P0131
Old Jul 25, 2009 | 06:34 PM
jonwymore's Avatar
jonwymore
Default trouble code P0131
P0131 Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 1 is the code im getting. Should i just replace it or.....?
Old Jul 25, 2009 | 09:24 PM
byronhunter's Avatar
byronhunter
Well, I would, but you could switch the 2 front ones, and see if the trouble moves to the other side.
Old Jul 26, 2009 | 02:16 AM
Last C5's Avatar
Last C5
Before you start replacing parts, check that the clamps on your intake are all tight from the MAF back to the throttle body. The lean code your getting is often caused by air leaks in this area. Code 0131 is usually accompanied by 0151 when this occurs, but it's worth checking first.
Old Jul 28, 2009 | 11:08 AM
jonwymore's Avatar
jonwymore
excellent thank you all for your replies
Old Aug 18, 2020 | 10:13 PM
levip22's Avatar
levip22
7th Gear
I have 0131, 0151 and 0102. Any ideas?
Old Aug 19, 2020 | 02:53 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
All 3 of these DTC’s are “low voltage” issues with both upstream O2 sensors and the MAF sensor...without a scan tool to look at the O2 sensors and MAF sensor it will be difficult to diagnose...a DVOM would be helpful to have !!
To trouble code P0131
