A different horn problem
Old Jul 25, 2009 | 08:15 PM
99 vett babycar's Avatar
99 vett babycar
Default A different horn problem
I've done all the searching and can't come up with anything I can use. My horn comes and goes. Every time I get in my car I have to hit the horn to see if I have one. If it works it will keep working until I shut the car off. When I re-start the car I hit the horn and it works(!) or it does not(?). If it's not working it will not start working until I shut the car off. It might take one try or two trys or it's just not going to work anymore today. Next day when I start it up it works or not - it's a crap shoot.It comes and goes on its own schedule. I've checked the grounds; asked the dealer if GM has put out a bulletin on the subject - no luck.
Any ideas?
Old Jul 25, 2009 | 09:29 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
The typical failure heard here is the horn membrane in the steering wheel is having issues. I think it only sends a command to the BCM which in turn sends a ground signal to the horn relay. I'm not sure of that fact and someone else can correct me if I'm wrong. I suppose you could have a hanging up horn relay in the engine compartment fuse box.
Old Jul 25, 2009 | 11:35 PM
dgrant3830's Avatar
dgrant3830
Cool. I knew the BCM was involved but now I know how exactly. Thanks 8VETTE7
Old Jul 25, 2009 | 11:50 PM
byronhunter's Avatar
byronhunter
When it won't work, listen under the hood for relay click. That will tell you if the trouble is before or after the relay. Post what you find. Relay # 36. Also, push the panic button on the remote, that tells the BCM to activate the horn.
Old Jul 26, 2009 | 09:02 AM
99 vett babycar
car's having some work done to it. I'll get it back mid-week and try this - good idea about the panic button, never thought of that.
Thanks Byron.
Old Jul 26, 2009 | 12:22 PM
filsvet's Avatar
filsvet
I have the same problem. Sometimes it works sometime it doesn't love to see what idea are out there I've got none ...
Old Jul 26, 2009 | 05:56 PM
dgrant3830's Avatar
dgrant3830
Ground pack G102 is where they are grounded. Good idea to look there. I think they're pictured in the electrical sticky.
To A different horn problem
