what happens when you add
Old Jul 25, 2009 | 10:55 PM
tramminc's Avatar
tramminc
Default what happens when you add
5 gallons of meth than full the tank wiith gas
Old Jul 25, 2009 | 10:56 PM
Superman09's Avatar
0Superman09
Former Vendor
it overflows? thats a lot of meth for a tank!
Old Jul 25, 2009 | 11:10 PM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
I'm thinking the DEA shows up at your door
Old Jul 25, 2009 | 11:19 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Up to 15 percent methanol can be added to gasoline in current cars, without adjustment of the engine, and with noticeable improvement in exhaust quality, economy and performance. Methanol has an octane rating of 106, compared to typical gasolines of 85 to 100. It prevents knocking or "pinging" common with unleaded fuels, and it alleviates "running on" or "dieseling" when the ignition is switched off.
Adding 5 gallons to a 19 gallon (tanks) goes over the line. I wouldnt do it.
Old Jul 25, 2009 | 11:54 PM
Its_Go_Time's Avatar
Its_Go_Time
Where did you get 5 gallons of nitromethane from.
That's the question.
Old Jul 26, 2009 | 01:45 AM
MYLS6's Avatar
MYLS6
I get mine from a local race shop in Columbia,SC
Old Jul 26, 2009 | 02:27 AM
Its_Go_Time
What would be cool is if you could seperate the two fuel tanks and just use the left tank for gasoline. Fill the RH tank thru the trunk with nitro methane. Also, maybe hydrazine in the windshield washer tank, for a rainy day. Nothin' but a big red switch on the end of the shifter.
Old Jul 26, 2009 | 03:55 AM
oakvillec5's Avatar
oakvillec5
Old Jul 26, 2009 | 11:43 AM
tramminc's Avatar
tramminc
One of my vendors (Dennis K. Burke oil & racing fuel) has it in 5 gallons for $35.00 or 55 gallon drums.
http://www.burkeoil.com/
Old Jul 26, 2009 | 12:26 PM
Chevy Guy's Avatar
Chevy Guy
Absolutely nothing. Your car likely isn't set up to benefit from it.
Old Jul 26, 2009 | 01:26 PM
zeevette's Avatar
zeevette
Doesn't do anything without a power adder with adjustable boost to take advantage of add'l octane, or timing adjuster.
Old Jul 26, 2009 | 01:43 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
, methanol bro, not nitro.
Stop posting, start calling Don Kinder more often
Old Jul 26, 2009 | 01:58 PM
Its_Go_Time
It was a joke, bro. Who's Don Kinder?
Old Jul 26, 2009 | 06:07 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Go that far, might as well use unsymetrical diamethyl(sp) hydrazine and go all the way. Hit the big red button and catch up to the space shuttle real fast!
Old Jul 26, 2009 | 06:53 PM
vetterdstr's Avatar
vetterdstr
Screw that... dilithium crystal's are way better... Just get a handful of those and forget about everything else.
Old Jul 26, 2009 | 09:11 PM
TEXHAWK0's Avatar
TEXHAWK0
Your fuel system will corrode.
Fuel with alcohol contains ethanol, not methanol.
Old Jul 26, 2009 | 11:26 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
The people behind your car get very very happy??????
To what happens when you add
Old Jul 27, 2009 | 12:18 AM
tommie's Avatar
tommie
Old Jul 27, 2009 | 12:26 AM
TheWildcat's Avatar
TheWildcat
Default spit and sputter
we had to add 5 gal to the gas tank to get home from the Kart races years ago... spit sputter.....lol ..JOHN
Old Jul 27, 2009 | 09:59 AM
SteveDoten's Avatar
SteveDoten
re: Hydrazine, F16 crewchief's pull the EPU pin every launch, Flow, NO Flow
always good to have O3 or above in the seat
