When should you upgrade your injectors?
Old Jul 27, 2009 | 05:35 PM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Default When should you upgrade your injectors?
Big cubes, Forced induction, and NO2 aside, when is is a good idea to upgrde your injectors to support your engine's power mods?
Old Jul 27, 2009 | 06:00 PM
ttribe's Avatar
ttribe
You live right around the corner from me if i remember right. EG tuned my car recently.
at 426 RWHP, my stock injectors hit 110% duty cycle at around 6k RPMs on a dynojet.
I upgraded to 42# and now am around 50% DC
EDIT: If I had it to do over I would have bought 60# so i would never have to upgrade again. When I go FI, i will put in 60 and sell the 42s since I have to pay for a new tune anyways. Also, with a 110% DC on a dyno, it may be higher on the street when under heavier loads.
Old Jul 27, 2009 | 06:12 PM
SDPC's Avatar
0SDPC
Former Vendor
When they can't supply with your engine with enough fuel. It really varies. Most mild heads/cam setups are fine with stockers, your 32s will easily support what you want to do
Old Jul 27, 2009 | 06:18 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Good to hear.
Stubner Airline betwen Louetta and Spring cypress?
Old Jul 27, 2009 | 06:42 PM
ttribe's Avatar
ttribe
I live off Kuykendahl between 2920 and Woodlands Parkway
Have too hook up some time, I'd like to see the corvette that can be seen from outer space
Unless you already upgraded injectors, I am pretty sure the c5z comes with 26 or 28#, not 32s.
Old Jul 27, 2009 | 07:58 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
I upgraded to the 32s when my origionals started failing.
Old Jul 27, 2009 | 08:51 PM
clif's Avatar
clif
St. Jude Donor '09-'10
Just monitor the duty cycle. That will show you exacly how they are performing.
Old Jul 27, 2009 | 11:01 PM
Corvette Don's Avatar
Corvette Don
My stockers were too small too, I went to 58lb and am at about 45 or so % if I remember correctly. I rev to 6600 rpm also.
Old Jul 27, 2009 | 11:06 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
How do i do this?
Old Jul 28, 2009 | 01:14 AM
HWY HNTR's Avatar
HWY HNTR
hp tuners, etc.
Old Jul 28, 2009 | 06:39 PM
Matt@Texas-Speed's Avatar
Matt@Texas-Speed
Premium Supporting Vendor
Originally Posted by TheRadioFlyer
How do i do this?
Good advise! In HPTuners you can monitor the duty cycle easily. We recommend changing them when you get to about 85-90% Anything beyond there and they are basically going static and just being held open constantly without control.
__________________
Largest Stocking Distributor of LS-x Engines / Largest LS-x Comp Cams Distributor in the Country!
COMP - FAST - PACESETTER - CALLIES - COMETIC GASKETS - MONSTER CLUTCHES - MOSER ENGINEERING - KOOKS
ARP - GM BOLTS AND GASKETS - MSD - NGK - POWERBOND - WISECO - ASP - AND MORE!
Old Jul 28, 2009 | 07:20 PM
HWY HNTR's Avatar
HWY HNTR
They can run 9X% no problem at redline but Matt is right.
Old Jul 28, 2009 | 07:36 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Some tuning should be done before deciding if larger injectors are really needed.
If the car is running rich at WOT (and adding headers, heads, cam etc w/o tuning will cause exactly that)...the reported injector duty cycle will reflect that and read higher than what it needs to be, for those given modifications, simply because the PCM (mis)calibration is adding more fuel than necessary.
If the measured AFR is tuned in and acceptable, and duty cycle is still much over 80%, then an upsize is in order.
Generally speaking, the stock 28# injectors should be good to at least 410-420 rwhp. They will handle all bolt-on mods with ease, and many cam-only cars.
For most heads/cam cars, the red top SVO 30s will work nicely and support over 450rwhp no problem.
Above that...there are some 36-38# options out there for the 470-520rwhp range, and 42s should work good in the 550rwhp ballpark.
Larger injectors don't make more power, they only feed the power the engine is capable of making. Size them correctly (bigger is not always better), and enjoy a good running car.
To When should you upgrade your injectors?
