Different poly motor mount options?
Old Jul 27, 2009 | 10:23 PM
civlant's Avatar
civlant
Default Different poly motor mount options?
I see that Pfadt makes a very quality piece as well as VBP but what about the ones that are a bit cheaper on the auction site? Anyone try those? After my H/C setup I would like to try some stiffer motor mounts but $250 is pricey...my Trans Am was like $50 for poly mounts!
Old Jul 28, 2009 | 11:23 AM
2_99_c5s's Avatar
2_99_c5s
Ultra mount makes urethane motor mounts that go for $100 on eBay. They warranty the mounts with a lifetime warranty. If it breaks they claim that they will replace the mount and give you your money back. Plus the 800 number is on the mounts, so it seems that they stand by their products. Plus, if you wanna get crazy they have solid aluminum mounts for $40.
Old Jul 28, 2009 | 06:59 PM
civlant's Avatar
civlant
I saw those I just wasn't sure about the quality/ease of installation like Pfadt. If they fit fine then I'm sure urethane/poly is all pretty much the same right?
Old Jul 29, 2009 | 10:21 AM
TurboBerserker's Avatar
TurboBerserker
I just installed their solid mounts. Installation is a breeze and the workmanship appears to be top notch.
Old Jul 29, 2009 | 11:12 AM
civlant's Avatar
civlant
Are you talking about the Ultra ones?
Old Jul 29, 2009 | 11:47 AM
TurboBerserker
Yep
Old Jul 29, 2009 | 03:21 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Why do you want to change the mounts? Have yours failed?
Old Jul 29, 2009 | 05:53 PM
civlant's Avatar
civlant
Mine are fine but I've got a very low rpm rattle/knock that you can really only hear if it dips below say 800 rpms. Also it's picking up some knock b/w 3200-3800 and I just want to eliminate any rattling from being the source. I had poly mounts on my Trans Am and it didn't bother me at all. From the sound of it they're much easier to install on a C5 than the F-bod.
Old Jul 31, 2009 | 12:43 PM
cdconklin's Avatar
cdconklin
I have had both solid & poly mounts from Ultra and I'm greatly pleased, best bang for the buck...
Install is easy...
hope this helps,
Old Jul 31, 2009 | 01:19 PM
Eric D's Avatar
Eric D
Install is easy...
hope this helps,
Do you mean “best bang for the buck” in increased vibration and noise?
Old Jul 31, 2009 | 05:34 PM
cdconklin's Avatar
cdconklin
I mean compared to all the other options, Ultras are the way to go. I took out stockers for the solids and they greatly increased noice and vibration, the poly are inbetween stockers and solids and are more my taste.
Old Aug 3, 2009 | 12:12 PM
Aaron Pfadt's Avatar
Aaron Pfadt
St. Jude Donor '08
Autocross & Roadrace Forum Sponsor
I wish that was true. Poly is one of the best and worst materials all at the same time. It has some great properties and some terrible properties that all have to be accounted for in a design. There are also many different grades of polyurethane that have different damping characteristics and different durability. We have spent a lot of time tuning the exact characteristics of our mounts, hence the customer satisfaction that we have.
The Pfadt mounts use a set of replaceable poly 'hat bushings' that have a carefully calculated amount of deflection. It is difficult to get the correct balance between isolation of vibration and control of movement. At Pfadt we have developed a very lightweight design that holds the engine in place without causing any annoying vibration in the interior. Also with the Pfadt design, the engine is captured regardless of the state of the polyurethane. That way even if the poly fails, the engine will still be held in place. That is not the case with many designs.
Pfadt C5 Engine Mounts
-Aaron
Old Aug 3, 2009 | 08:57 PM
vsocks1's Avatar
vsocks1
-Aaron
Do you have installation instructions for these that I can have? Own a set just haven't taken the time to install yet. I have the Pfadt trans mount and am very satisfied with it - design & quality!
Old Aug 7, 2009 | 04:28 PM
jordan@pfadtracing's Avatar
jordan@pfadtracing
St. Jude Donor '08-'09
We have all of our instructions on the website HERE. We appreciate the comments and thanks for choosing Pfadt products! Please feel free to call or email us anytime and have a great weekend!!!!
Kind regards,
Old Aug 19, 2009 | 08:16 PM
dmiz0420's Avatar
dmiz0420
Ok Here's my ultra mount experience...
They are 1/4 to 3/8 inch higher than the stock mounts and I ran into clearance issues when installing my FAST intake. Not wanting to cut my fire wall, I'm looking for other options.
If your running a LS6 or stock ls1 intake it will probably be fine.
Its a lot of work to get to putting on the intake manifold and to find out the marginal height increase is a real issue. It would definately be worth the extra $$ not to have to reinstall them. Looks like I should schedule another day under the car.
Jordan,
How tall are your mounts?
THanks
Old Aug 19, 2009 | 09:25 PM
civlant's Avatar
civlant
Jordan,
THanks
What kind of mounting issues did you have with the FAST? I put my FAST on with the ultra mounts and didn't have any issues.
Old Aug 19, 2009 | 11:31 PM
Aaron Pfadt
St. Jude Donor '08
Jordan,
THanks
Our mounts are exactly stock height. With the Pfadt mounts your engine will be in the same place as with the stock mounts.
-Aaron
To Different poly motor mount options?
Old Aug 20, 2009 | 08:43 AM
dmiz0420's Avatar
dmiz0420
Thank you Aaron, I'm going to see if willfulone has any here locally for purchase.
My Map sensor is hitting the back of the firewall.
If you look at the ultra mount products offered, it looks like the mount might be the same as a Supra mount. I think they just use a steel core with a threaded rod through it and sorround the whole thing with polyurathane, so basically it's a solid mount. I don't think there's anything wrong with that, but the height should be a little lower.. about 1/4 to 3/8 inch.
I managed to turn my map sensor around (harness connecting to the drivers side) and get enough slack in the connecting wireing harness that after givning the harness and sensor a little guidance, the manifold was able to pop into place. Now I just need to do it while holding up the bolts.
The only thing that worries me is that, esp with the headers, what other clearances aren't what they should be?
Old Aug 20, 2009 | 12:53 PM
civlant's Avatar
civlant
I see - but I thought the MAP sensor hitting was a common problem with the FAST on our cars? I found a MAP relocation that guys who put the FAST on have done with their C5's and they have stock motor mounts. I did the relocation so now there's a 3/8" barbed 90 deg fitting where the MAP hole is on the FAST and then a 3/8" hose going about 6" over to the MAP.
Old Aug 20, 2009 | 01:36 PM
dmiz0420's Avatar
dmiz0420
Sounds like this is a common issue that is easily overcome, I found a lot of posts on it as well.
The C6 guys have a lot more work to do to make their FAST fit.
All in all the mounts are in and considering the work involved, they are staying that way for now, there's nothing wrong with them, and I'll eventually be back in there... So may as well give it a go.
