BBK vs LS6 Intake
Old Jul 28, 2009 | 03:02 PM
Michael99Vette's Avatar
Michael99Vette
Default BBK vs LS6 Intake
Can anyone tell me which intake is better for my 99 Vette... the LS6 or a BBK SSI series (LS1 LS6) intake. Both are used and appear in, like new condition. It looks like the BBK may end up costing $100 or more, than the LS6. If the BBK is better, is it worth the extra money.
Old Jul 28, 2009 | 03:26 PM
Daddyrama31's Avatar
Daddyrama31
BBK makes great products. However, you can not go wrong with an LS6 intake. It is one of the best intakes ever designed by GM. You will be pleased with the performance you get from it.
Old Jul 28, 2009 | 03:45 PM
lucky131969's Avatar
lucky131969
Old Jul 28, 2009 | 04:41 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
LS6 for your setup
Old Jul 28, 2009 | 06:32 PM
Matt@Texas-Speed's Avatar
Matt@Texas-Speed
Premium Supporting Vendor
You can find slightly used LS6 intakes in the classifieds forums here and on other forums for about $300 or so all the time. You can't go wrong with the LS6 for the money. I'm not a big fan of the BBK.
__________________
Largest Stocking Distributor of LS-x Engines / Largest LS-x Comp Cams Distributor in the Country!
COMP - FAST - PACESETTER - CALLIES - COMETIC GASKETS - MONSTER CLUTCHES - MOSER ENGINEERING - KOOKS
ARP - GM BOLTS AND GASKETS - MSD - NGK - POWERBOND - WISECO - ASP - AND MORE!
Old Jul 28, 2009 | 07:21 PM
bstone1989's Avatar
bstone1989
^^ u can also get a new ls6 intake on ebay for $325
Old Jul 28, 2009 | 07:54 PM
~Josh's Avatar
~Josh
Banned Scam/Spammer
I have polished Weiand/Lingenfelter intake because of my overall engine... otherwise I would have kept the LS6. The Weiand does have more torque compared to the factory oem... No dyno sheets, just perception.
Not sure how the BBK is made internally, I think it's one ugly intake on the outside, I'd never buy one.
Old Jul 28, 2009 | 08:05 PM
GETOPLES's Avatar
GETOPLES
ls6 and be done with it.
Old Jul 28, 2009 | 08:13 PM
dpw41285's Avatar
dpw41285
only reason i ran a aluminum intake was due to having burst panels for nitrous. it was a weiand that i had port matched and opened up to accept 85mm tb. that being said an ls6 would be just fine and if its cheaper there is your answer. btw several test were done as far as heat soak.... i wont give my opinion
Old May 10, 2011 | 09:30 AM
DanFRC's Avatar
DanFRC
4th Gear
Lucky, you do realize that this forum gets new members everyday. I think you've been around so long that you know all the answers to the questions that the new guys have. So instead of being sarcastic, just move on and let someone else answer.
Old May 10, 2011 | 09:42 AM
mmartinez's Avatar
mmartinez
Default Amen
Amen
Old May 10, 2011 | 10:12 AM
lucky131969
Outstanding follow up on this almost 2 year old thread.......and after further review...........
To BBK vs LS6 Intake
