Do I need a new fuel pump?
Old Jul 29, 2009 | 09:37 AM
JSTAN's Avatar
JSTAN
Default Do I need a new fuel pump?
I have an 02 Z06 with a Magnacharger, 42 lbs injectors.
Recently I noticed a "skipping" sensation under heavy acceleration. During heavy acceleration my fuel pressure drops from 58#'s to 50 - 52 #'s.
I am assuming my fuel pump is on its last legs. I purchased the car with the magnacharger already installed so I am not sure it has an aftermarket pump.
The car has 25k miles, I would think the fuel filter is still good.
Any advice on tests to run against the pump or should I be worried about something else?
Old Jul 29, 2009 | 02:01 PM
ovrpar6's Avatar
ovrpar6
Pour some Seafoam or Techron in the tank
Old Jul 29, 2009 | 03:09 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Any change in engine rpm when this is happening? Clutch slip???
Old Jul 29, 2009 | 03:36 PM
JSTAN's Avatar
JSTAN
Its a brand new clutch, no change in the RPM that I noticed.
Old Jul 29, 2009 | 03:45 PM
lucky131969's Avatar
lucky131969
How exactly does this affect fuel pressure?
Old Jul 29, 2009 | 08:01 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
Do you have a wide band O2 sensor and meter? I would check the F/A ratio at WOT before making a determination that 50 -52 PSIG is too low for your application.
In 02 I believe the fuel pressure regulator was integral with the filter.
Old Jul 29, 2009 | 09:25 PM
JSTAN's Avatar
JSTAN
I figured out the problem thanks to my tuner Slowhawk. I told him the symptoms and he said it sounds like a bad plug or wire. Well I just got down swapping out the plugs and one of them had 3 hair line cracks. Anyway the problem is gone.
To Do I need a new fuel pump?
