Steering telescopic function
Old Jul 31, 2009 | 11:26 PM
alwysnxs's Avatar
alwysnxs
Default Steering telescopic function
The telescopic function for my steering wheel has stopped working. Is there a fuse for that I might have blown. If so, where is it located? Thanks!!!
2003 Corvette
Old Aug 1, 2009 | 12:19 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I'm not sure about a fuse however, I do know it gets its power via the driver's seat blue 7-pin connector under the seat. You might want to see if its still connected.
Old Aug 1, 2009 | 01:32 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
It's also possible the soft stops have engaged, although I'm not sure they do with zero travel. To check press, hold and release the button at least 7 times or until it starts moving...
Old Aug 1, 2009 | 09:35 AM
Patches's Avatar
Patches
Telescoping Steering Column Calibration
Telescoping Soft Stops
After replacement of the seat control module, it is necessary to program the telescoping soft stops. Each soft stop is a programmable end of travel that is set approximately 1.3 cm (0.5 inch) from the mechanical end of travel. The steering column has a soft stop set at each end of the telescoping in/out movement. The system uses soft stops to prevent wear on the system by ensuring that the steering column movement stops before it reaches its mechanical end of travel in any direction. The soft stops are initially programmed at the factory. The stop positions may be reprogrammed, which is necessary any time the seat control module is replaced, as described in the following procedure.
Telescoping Soft Stop Programming Procedure
1] Turn ignition to ON, leaving the engine off.
2] To set the telescoping in soft stop, press the telescoping COLUMN IN switch at least eight times or until the column moves.
3] Press the telescoping COLUMN IN switch and hold the switch until the column travels all the way in, and continue to hold the switch about a second after motion stops at the mechanical end of travel. The soft stop for the column in position is now set. The seat control module automatically goes back to the normal mode of operation.
4] Repeat steps 2 and 3, using the COLUMN OUT switch, to set the column out position soft stop.
Old Aug 2, 2009 | 03:08 AM
tstar's Avatar
tstar
Or eight times!
Tim
Old Aug 2, 2009 | 03:25 AM
Eric the Ricer's Avatar
Eric the Ricer
From: Beyonce > Taylor Swift - Welcome to the good life!
St. Jude Donor '07
What year did this telescoping wheel come on?
Old Aug 2, 2009 | 07:02 PM
dgrant3830's Avatar
dgrant3830
My '99 had it.
Old Aug 3, 2009 | 09:54 PM
corvette77's Avatar
corvette77
This happened to me this past June. I happened to read another post discussing this very issue. Worked like a charm and have not had any problems since.
Old Aug 16, 2009 | 01:52 AM
alwysnxs's Avatar
alwysnxs
AMAZING!! Worked like a charm.
To Steering telescopic function
