Differential fluid change?
Old Aug 1, 2009 | 04:34 PM
Fritz96's Avatar
Fritz96
Default Differential fluid change?
I'm up to 145,000 miles on my 2000, but haven't had my differential fluid changed yet. At this late point, should I change it or am I best to just leave the old fluid in it?
Old Aug 1, 2009 | 04:46 PM
81c3's Avatar
81c3
I would change it, but thats just me. Actually I would be on my 3rd change with that mileage.
Old Aug 1, 2009 | 06:24 PM
ALLEGRO's Avatar
ALLEGRO
Cheap PM, I would say you have nothing (well I guess the cost of the change) to lose.
Old Aug 1, 2009 | 07:08 PM
YeloFevr's Avatar
YeloFevr
Change it!!!!! And every single other fluid while you're at it!!!
Old Aug 2, 2009 | 07:08 AM
rws.1's Avatar
rws.1
Don't leave it... change it....
buy 2 qts quality synthetic gear oil 75W90 and 1 bottle of GM limited slip additive ( or the aftermarket additive)
puit in the additive first and them fill with the gear oil.... you should get about 1.7 qts of the gear oil in
Old Aug 2, 2009 | 10:43 PM
moserbe's Avatar
moserbe
Is your brake fluid clear or black?? May be time to change that also.
Old Aug 3, 2009 | 01:10 PM
Fritz96's Avatar
Fritz96
Thanks for the replies. I questioned whether to change it because I've read that with transmissions if you haven't changed the fluid by 100K, it's better to leave the old fluid in there.
Old Aug 3, 2009 | 01:22 PM
LoneStarFRC's Avatar
LoneStarFRC
One caveat however. Make SURE you know that whichever brand of lube you choose, either DOES or DOES NOT already have the limited slip additive already in it. SOME BRANDS DO. Red Line and Amsoil most notably. Not sure about Royal Purple.
Point being, if a lube already has the limited slip additive premixed in the product, and then you go and add yet another full bottle of additive on top of that, it could easily wind up being entirely too much additive in total and cause excess slippage of the clutch plates, etc.
If in doubt, check it out. Other than that, it's a pretty much straightforward drain/refill deal.
HTH
To Differential fluid change?
