Problem: Service Engine Soon + ABS Light + Traction Control Light
Old Feb 15, 2002 | 08:25 PM
lioninavette's Avatar
lioninavette
From: Ponderables, yes. My opinion, not totally. Preaching...I don't have a pulpit. Fact and generalizations about what I am reading on behalf of what you tell me...absolutely.
Default Problem: Service Engine Soon + ABS Light + Traction Control Light
On the way home from work today, the Service Engine Soon message appeared, along with the ABS Light and Traction Control. This happened about 1.5 mi from home. Got home, parked in the garage, turned car off, turned it back on, and nothing. I drove the car to work today, and it has been about a week since I last drove the car. Has anyone had this happen to them and/or know what this means? I looked in the manual, but didn't see anything.
Thanks.
Ron
Old Feb 15, 2002 | 10:12 PM
Charlie LI NY's Avatar
Charlie LI NY
Default Re: Problem: Service Engine Soon + ABS Light + Traction Control Light (lioninavette)
Same thing this morning. What gives?
:crazy: :crazy: :crazy: :crazy: :crazy:
2001 MN6 coupe
codes: P1431H
C1288H
[Modified by Charlie LI NY, 9:12 PM 2/15/2002]
[Modified by Charlie LI NY, 9:48 PM 2/15/2002]
Old Feb 15, 2002 | 10:33 PM
00c5coupe's Avatar
00c5coupe
same here....ABS light came on two times within about three months.
Old Feb 16, 2002 | 04:54 AM
barryscott's Avatar
barryscott
Hey Now:
First thing I would do, check your codes, and let us know. :yesnod:
Old Feb 16, 2002 | 11:24 AM
UNX PGMR's Avatar
UNX PGMR
Could be:
Yellow: Traction Control/Handling Lamp On, Drivers Info Center Displays Service Active Hndlg (Handling) (Repair/Reprogram ABS Module) #01-05-25-004
Yellow: Traction Control/Handling Lamp On and Driver's Info Center Displays Service Active Hndlg (Handling) (Repair/Reprogram ABS Module)
2001 Chevrolet Corvette
Condition
Some customers may comment that the "Yellow" message, "Service Traction Active Handling", is illuminated on the Driver's Information Center.
The technician may find chassis DTC C1288 -- Vehicle Stability Enhancement System (VSES) Steering Wheel Sensor Phase A and B. When this code is set, the VSES is turned off; ABS and TCS remain operational.
Old Feb 16, 2002 | 03:45 PM
zoomnz's Avatar
zoomnz
I too had this happen to me about 3 months ago. It has not come back since. I had put her in COMP mode a couple of times riding around before this happened. Once I got home, cleared error code...dont remember which one it was..I wrote it down, but it's at the house, as I am at work now. Anyways, problem has not shown back up again. I thought it might of had to do something with toggling COMP mode on/off...Did you toggle between performance modes before your error light came on???
ZOOMNZ
Old Feb 16, 2002 | 04:53 PM
Byter's Avatar
Byter
Hi All,
I was getting the same thing. I disconnected the harnesses for the wheel sensors (located in back of the front wheels) and applied some dilectric grease to the plugs. I haven't had a problem since.
Same thing happened with my fuel injectors. Seems the plugs can get a little dirty and/or galvanized.
Hope this helps...
To Problem: Service Engine Soon + ABS Light + Traction Control Light
