Passenger Door not unlocking
Old Aug 4, 2009 | 04:17 PM
flexvette's Avatar
flexvette
Default Passenger Door not unlocking
First started as an intermittent problem, had to hit keyfob more than twice.Drivers door always unlocks on first press of kfob. Now passenger side not working at all. Have to manually unlock. A pain.:ack
Any suggesttions? :
2003 Coupe QS M6 Canadian car. No mods. All original. 31,000 km and still beautiful.
Old Aug 4, 2009 | 04:41 PM
Chicago1's Avatar
Chicago1
Very common problem on these cars do a search under door control module. You should find a diy faq to fix it or change it out.
Old Aug 4, 2009 | 04:46 PM
flexvette's Avatar
flexvette
Thanks Chicago1 . Will try that. Hoping it was just a loose wire as I have not had to spend one nickel on this car since new.
Old Aug 4, 2009 | 11:57 PM
striper's Avatar
striper
This happened on both of my doors at two separate times. It is the door control module. Some people have repaired them by changing relays inside the module. I was fortunate that I had warranty coverage both times. Very easy to access the modules in the doors.
Old Aug 12, 2009 | 08:51 AM
flexvette's Avatar
flexvette
Did the repair yesterday. Removed door module, desoldered the offending relays. Purchased quality relays, made in USA. Cost $6. Could have purchased Asian relays for 1.77cd but did not want the same thing happening again in a few yrs.(or less). The USA relay was heavier than the Thialand made unit. That tells you something. Fact of the matter, GM puts the cheapest parts that they can get without concern for the consumers satisfaction. Still charge a lot of $$$ for the car. If they don't change their attitude they will be in trouble again. High end cars should have high end parts. I expect that, but also expect low end cars to have low end parts.
Thanks to all those that chimed in with advice.
Old Aug 12, 2009 | 11:53 AM
Pchild's Avatar
Pchild
Not that I'm anti-American at all. I'm all for buying "USA" products. But thinking that American products are superior to all Asian products is a pretty hefty stereo-type. Wonder where the internals for that relay came from? Possibly all USA produced, but possibly not.
I bet you wouldn't take an American Plasma screen over your Panasonic, or Sony. =P Asian markets produce the finest electronics in the world, and also the worst.
Glad you got your problem fixed. My wiring messed up a while back and I wasn't locking the passenger door either, until my GF opened it and set the alarm off I had no idea it wasn't locking.
Old Aug 15, 2009 | 08:33 AM
jimcork1's Avatar
jimcork1
I have had a door module also fail. Just wondering do you have any details of the repair you made or type of relay and how you installed it. Thank you ... vettdvr
Old Aug 15, 2009 | 01:33 PM
Bakersfield's Avatar
Bakersfield
Read this post I wrote. It should answer all of your questions.
http://forums.corvetteforum.com/c5-g...w-problem.html
Old Aug 15, 2009 | 01:51 PM
lucky131969's Avatar
lucky131969
Fact of the matter, huh? Please share your knowledge on the automotive electronics qualification process....
Old Aug 15, 2009 | 05:01 PM
jimcork1's Avatar
jimcork1
thanks.
To Passenger Door not unlocking
