tire dummy
Old Aug 5, 2009 | 09:56 PM
cleti99's Avatar
cleti99
7th Gear
Default tire dummy
I currently have a 1999 with 245/45/R17 on front and 285/35/zr18 on the back that needs new tires...should I just replace them with the same sizes or something different..anyone have any suggestions?
Old Aug 6, 2009 | 12:37 PM
97C5owner's Avatar
97C5owner
What rims are on the car?
Old Aug 6, 2009 | 01:03 PM
cleti99's Avatar
cleti99
7th Gear
Default rims
It currently has the stock rims on it...
Old Aug 7, 2009 | 12:08 AM
97C5owner's Avatar
97C5owner
285mm is a bit wide, not too much, but a bit wide for the 9.5 in factory wheels. I'd go back with the 275mm factory size tire. You will have a more true contact patch with the pavement. Oversize fitments can be compensated for somewhat by lowering air pressure, but now you sacrifice handling and fuel economy. Hope this helps.
-97C5 14yr asst mgr major tire chain
Old Aug 7, 2009 | 09:13 AM
j84buick's Avatar
j84buick
With stock rims some have gone a little bigger but you are probably better to stay with stock sizes. Plus you get a ton of options for those sizes. Those of us who went with a 18x10 & 19x11 rim over the stock 17x8.5 & 18x9.5 have far fewer (and more expensive!) options.
Old Aug 7, 2009 | 09:16 AM
97C5owner's Avatar
97C5owner
But it looks so much sweeter....!
To tire dummy
