Plug Wire Shields.......Necessary?
Old Aug 7, 2009 | 08:43 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
Default Plug Wire Shields.......Necessary?
Are the metal shields on the plug wire ends there for heat shielding, or used only for RFI supression?
I'm installing a set of GM Performance Parts red wires, and need to know if I should reuse the shields from the factory plug wires or not.
Old Aug 7, 2009 | 09:08 AM
lucky131969's Avatar
lucky131969
Why wouldn't you? Is there a downside to a little extra protection for the plug wire boots?
Old Aug 7, 2009 | 09:19 AM
dankhts's Avatar
dankhts
I installed the GMPP red wires and re-used the metal shields......you should use -em again too...
Old Aug 7, 2009 | 09:39 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The shields are actually there for EMI/RFI but do protect the boots also. They fit the red wires like a glove so,,, theres ZERO down side to using them. Believe me. If GM didnt think that they needed to be there, they wouldnt be there. They serve a purpose however slight it may be.
I use them on my 02 ZO6 and my 06
To Plug Wire Shields.......Necessary?
