NGK TR6 Plugs - Gap?
Old Feb 16, 2002 | 10:56 AM
racetchr's Avatar
racetchr
Default NGK TR6 Plugs - Gap?
Anybody have a suggestion for the gap on these plugs? I am currently using .50 w/Nology wires but can't seem to find the exact specs.
Old Feb 16, 2002 | 12:02 PM
MelloYellow's Avatar
MelloYellow
Default Re: NGK TR6 Plugs - Gap? (racetchr)
TR6's Max gap is .043
Normally this plug is used for NOS or FI apps.
Tends to foul in a stock or H/C engine.
Old Feb 18, 2002 | 01:14 AM
racetchr's Avatar
racetchr
Default Re: NGK TR6 Plugs - Gap? (MelloYellow)
thanks for the info - I gapped at .050 after going to NGK's website and this is what they recommended. I am going to pull them in a week and see what they look like.
Old Feb 18, 2002 | 01:37 AM
MelloYellow
Np. TR55's are normally .050-.055
Not sure what they put online. Standard LS1 gap is in that range.
Talked to NGK techs directly before I tried TR6's once and they didn't like me going past .040 and said anything past .043 is bent to far and out of spec.
Old Feb 18, 2002 | 01:59 AM
C5Cemo's Avatar
C5Cemo
I've seen the same results with the TR6 plug...gapped below 40 is ok but above is more risky. I installed a set that I gapped to 42 and I burnt one of the electrodes clean off...this is with some nitrous use, though. I gap them to 38 without any problems now.
Old Feb 22, 2002 | 01:57 AM
racetchr's Avatar
racetchr
Default Re: NGK TR6 Plugs - Gap? (C5Cemo)
thanks for the input. very valuable!
To NGK TR6 Plugs - Gap?
