Alternator Help.."98" C5 Coupe
Any reason for the problem other than the alternator.
Im trying to figure out if you have a compromised charging circuit from the alternator to the battery. Ive also used a battery jumper cable to do the test curb side.
BC
The volt meter on the IPC does NOT show ACTUAL battery voltage
It shows the voltage on the "HOT AT ALL TIMES" busses that come off the engine compartment fuse box B+ terminal.
That buss supplies voltage to the IGNITION 1 Circuit. That circuit goes thru "Instrument Panel Electrical Center,,, MAXI Fuse# 45 (60 amps)". From there it goes thru the "IGNITION SWITCH"! The IGNITION SWITCH supplies voltage to the IPC.
See,,,you made me blame the damn ignition switch already and the OP hasn't even written back ONE word!
See ,,,you knew that I was going to recommend that all along, didn't you?!
Now your going to make kg54trains read a whole different post and then do some work!
http://forums.corvetteforum.com/c5-t...ch-repair.html
See,,I blaming this all on you.
Im leaning toward a defective ignition switch.
kg54trains. If the ignition switch solves the issue,,please post in my ignition switch post. Im keeping tract on how many of these are becoming issues.
BC
BC
It does eliminate the issues. The guage will show 13.8-14.0 at start up and under a load of Headlights/Stereo the guage reading is 13.7-13.8. Ran the car with a load for 15-20 mins. If this is a alternator problem that will require replacement can you suggest a manufacture. GM is Mid-300 from gmpartshouse, and there are varies others down to 200. I will be also completing the ignation switch rehab but the heat/hum in the last week in SE PA has been tough. I hope this weather change does not continue because generally the weather is the same as Central PA. Do not need frying pan heat for that last weekend in August.
Use a DC Volt meter and with the engine running, read the positive battery terminal to the BATT terminal on back of the alternator. It should read ZERO volts DC. The more voltage it reads, the worse the connection is between the battery and alternator.
If you get any voltage, examine the solenoid and the wiring on the solenoid terminal.
BC
BC
I can't believe (although I should) that I'm still copying information. You have been helping forum members with For Years.
Thanks pal
Bob (210,000 miles)
So I did thread #2 on here and ran a wire directly from the positive post on the alternator to the positive post on the battery and the car is showing good charge. So now I know it is the wiring. Where should I start checking the wiring and where is the solenoid? Thanks so much.
