Help, when installing header on a c5
Old Aug 9, 2009 | 03:46 PM
tramminc's Avatar
tramminc
Default Help, when installing header on a c5
do you put lock tight on the bolt treads? reason for asking is because I see yellow looking dried marking on them.
I helping my son install them on his 03 zo6.
Old Aug 9, 2009 | 04:07 PM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
I would NOT do that. You don't want to take a chance of trashing the threads in the head when removing them in the future.
Old Aug 9, 2009 | 04:26 PM
tramminc's Avatar
tramminc
that makes since on aluminue heads, I never use lock tight on my 68 pontiac headers or any other old car.
Old Aug 9, 2009 | 06:20 PM
hotwheels57's Avatar
hotwheels57
Some new fasteners come with yellow (or red) thread locker on them.
The yellow always reminds me of cured 3M weatherstrip adhesive ("camel snot")...
Old Aug 9, 2009 | 07:41 PM
froman's Avatar
froman
maybe some antiseize lol.
Old Aug 9, 2009 | 10:33 PM
happa's Avatar
happa
I have never put thread locker on my header installs. Havent had any problems. Just torque them down
Old Aug 9, 2009 | 10:42 PM
C5FORFUN2's Avatar
C5FORFUN2
Would be a very good idea to use anti-sieze. Saves the aluminum threads if you ever need to remove them. I would use locking style header bolts so they don't come loose. Exhaust leaks are bad
Old Aug 9, 2009 | 10:51 PM
vsocks1's Avatar
vsocks1
I used ARP header studs with ARP moly lube. Torqued to spec and never loosened up - had them on/off a few times already.
Well worth it and no threadlocker needed!
Old Aug 9, 2009 | 10:54 PM
djengr's Avatar
djengr
I did not use any thread lock, but I did use anti seize and torqued down per spec.
Good Luck.
To Help, when installing header on a c5
