C5 Spring weights....
Old Aug 9, 2009 | 08:12 PM
LT1vette's Avatar
LT1vette
Default C5 Spring weights....
Does anyone have the specs for the front and rear springs? What is the difference between the stock and the Z06 specs?
TIA
Old Aug 12, 2009 | 10:46 AM
LT1vette's Avatar
LT1vette
tttttt
Old Aug 12, 2009 | 05:32 PM
CP Thunder's Avatar
CP Thunder
Here ya go..........
Old Aug 12, 2009 | 08:45 PM
pcbunn's Avatar
pcbunn
I notice the ZO6 front spring rate is 526 and a C5TI is 582, what is a TI? When I upgrade my front shocks I'm considering a slightly stiffer front spring. Hyperco street spring is rated at 565 and track is 625. The C5TI sounds like a good middle choice for the street but what is a C5TI ?
Old Aug 12, 2009 | 08:54 PM
CP Thunder's Avatar
CP Thunder
Its actually T1. Its the GM provided SCCA race car suspension setup............kit form has front upper and lower control arms, f/r springs, shocks and big swaybars...
Old Aug 12, 2009 | 08:57 PM
LT1vette's Avatar
LT1vette
Thanks Steve, now I just have to match the Gm part numbers up to see the pricing.....
Thanks Again
Old Aug 12, 2009 | 09:08 PM
CP Thunder's Avatar
CP Thunder
I think GM PARTS DIRECT (CF Vendor) can supply info ..... www.gmpartsdirect.com
Old Aug 13, 2009 | 02:36 AM
thetaxman's Avatar
thetaxman
isn't that the sway bar rates ?
not the springs ?
Old Aug 13, 2009 | 09:55 AM
CP Thunder's Avatar
CP Thunder
The bottom set of numbers are the spring rates.............
Old Aug 13, 2009 | 11:46 AM
thetaxman's Avatar
thetaxman
of the sway bars themselves ?
not the actual springs from what I see
Old Aug 13, 2009 | 11:49 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
I'm missing something here. Normally spring rate will have a displacement value to it. Like the sway bar has a spring rate of 6.51 Kg/mm.
The front spring has a range of low 9291 to high of 9958 N at 24mm of design camber. Don't know if that helps you any or not.
Old Aug 13, 2009 | 12:16 PM
CP Thunder's Avatar
CP Thunder
I wish I could remember who sent this to me ....... but ....... 'I was told by' them this chart represented the swaybar diameters (correctly) and the spring 'rates' of the installed springs.......(base vs z51 vs z06 vs T1)..........but I see the point.........
Calculating 'actual' spring rates would be greatly diversified by swapping bars, springs, pickup points etc between models (not being an engineer) I would assume..........
Old Aug 13, 2009 | 12:36 PM
CP Thunder's Avatar
CP Thunder
http://forums.corvetteforum.com/auto...s-97-04-a.html
Similar information on another thread............
To C5 Spring weights....
