Knocking - Vid
Old Aug 10, 2009 | 09:20 PM
Limp Noodle's Avatar
Limp Noodle
Default Knocking - Vid
Hey I was hoping someone could shed some light on my issue im dealing with my C5. (97 100km-60k miles)
Knocking doesn't go away when engine has warmed up, no power loss issues, temp and pressure all normal. Not sure if its lifter or piston slap? or something I haven't even thought about
http://www.youtube.com/watch?v=7_uiCVRHMxk
Old Aug 10, 2009 | 10:13 PM
JCamaro's Avatar
JCamaro
I can't hear anything...no sound
Old Aug 10, 2009 | 10:17 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Same here, no sound on your video.
Old Aug 10, 2009 | 10:18 PM
lucky131969's Avatar
lucky131969
That is the most quiet engine I have ever heard..
Old Aug 10, 2009 | 10:25 PM
deimis's Avatar
deimis
here's a bump for ya....reupload with sound
Old Aug 11, 2009 | 12:17 AM
Limp Noodle
Ahhh stupid photobucket here lets try youtube
Old Aug 11, 2009 | 05:18 AM
Blown 346's Avatar
Blown 346
It almost sounds like loose valvetrain. It sounds similar to injector pulse but amped up about 20 times.
Old Aug 11, 2009 | 07:36 AM
motorvation2go's Avatar
motorvation2go
I agree with Blown 346 that it's probably valvetrain related. Fairly 'high frequency' (thin?) tapping sound as opposed to a bottom end knock.
It's also possible that you have an exhaust manifold/port leak. These can present themselves as a surprisingly sharp metallic tapping sound. Try using a (2' long or so) piece of garden hose...one end to your ear and one for probing engine. This will help locate the source. Of course, be real careful not to get wound up in any moving belts etc.
Old Aug 11, 2009 | 08:57 AM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
Sounds like valvetrain to me too. Definitely NOT rotating assemble (i.e. spun bearing) knock. Loose rocker, bent pushrod, worst case scenario would probably be a dead lifter.
Old Aug 11, 2009 | 10:06 AM
lucky131969
Additionally, I would isolate to a bank, and pull the valve cover to inspect for a cracked valve spring....or lost needle bearings in a rocker.
Old Aug 11, 2009 | 12:10 PM
dgrant3830's Avatar
dgrant3830
I listened to it here on a laptop so the sound resolution isn't so great. With that understanding, it sounds like a cylinder is pushing compression past a head gasket. I agree with those above too in that the valve train needs to be examined right away. Could be a valve not quite closing. A cylinder leak down test will show that. A compression test will do the rest.
Old Aug 11, 2009 | 01:56 PM
Chevy Guy's Avatar
Chevy Guy
First thing I would do is check for an arcing plug wire. Sometimes a plug wire can come loose and arc to the plug in such a way that it still fires. This is unlikely but worth a shot.
The next step would be to pull that valve covers and cover the points already mentioned above. It sounds like an issue with the valve train, maybe a bad rocker or lifter.
Old Aug 11, 2009 | 02:04 PM
dgrant3830's Avatar
dgrant3830
Pull the plugs and see if anything is to be found there? Maybe one cylinder isn't firing at all? Have you pulled the codes yet?
Old Aug 11, 2009 | 02:09 PM
knyght4's Avatar
knyght4
That sound reminds me of the knocking I was getting last month. Turns out that one of the spark plugs wasn't tight and it was slowly backing itself out of the head. The knocking was coming from the wire boot hitting the headers. Just a thought, but it may not be that easy for you.
Old Aug 11, 2009 | 11:24 PM
Limp Noodle
Ive never pulled the valve covers off before, should I expect oil everywhere or any suggestions/tips?
thanks for all the help, ill take em off hopefully tomorrow and take some pics
Old Aug 11, 2009 | 11:31 PM
dgrant3830's Avatar
dgrant3830
Very little actually but use some shop rags just to make sure nothing drips on the exhaust.
Old Aug 11, 2009 | 11:48 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
It also sounds like an exhaust leak. If you rev the engine and let it coast down,,,does the noise go away?? If so, thats an exhaust leak.
Could also be a valve train issue. You can remove the valva cover and there will be very little oil. The gasket is an O ring and reuseable.
Check rockers for puked roller bearings bent pushrods.
BC
Old Aug 11, 2009 | 11:51 PM
SilentFright's Avatar
SilentFright
From: Arlington Texas, originally from San Angelo, TX
Originally Posted by Bill Curlee
It also sounds like an exhaust leak. Could also be a valve train issue. You can remove the valva cover and there will be very little oil. The gasket is an O ring and reuseable.
BC
Old Aug 12, 2009 | 06:14 AM
Atok's Avatar
Atok
I think it's valve train related. Bad rocker, collapsed lifter, bent push rod? If you have a stethoscope use it to help isolate where the noise is coming from.
To Knocking - Vid
