Front turn signal out...
Old Aug 12, 2009 | 10:49 PM
SFL_driver's Avatar
SFL_driver
Default Front turn signal out...
How do I get to the turn signal bulb on the front passenger side to change it?
Old Aug 12, 2009 | 11:00 PM
byronhunter's Avatar
byronhunter
I like to go from the bottom, have a lift. Others have other ideas, and you'll be sure to hear from them.
Old Aug 12, 2009 | 11:07 PM
jrose7004's Avatar
jrose7004
There's a access panel right under it.
Old Aug 12, 2009 | 11:27 PM
rws.1's Avatar
rws.1
Or from above, manually raise the headlight, remove the bezel reach in and down find the bulb, squeeze and twist on the socket....
or through the brake vent reach it and push the accordian like duct out of the way, reach in find the bulk, squeeze and trun the socket.....
Old Aug 12, 2009 | 11:31 PM
itzza427's Avatar
itzza427
Regardless of which way you go,,it's a tight squeeze if you have larger hands!! My drivers side fog and passenger side turn went out,,so I bought them all and changed them!! Raised the aim on the fogs while I was at it!!
Old Aug 13, 2009 | 01:56 PM
TEXHAWK0's Avatar
TEXHAWK0
If you don't might scratching up your arms, you can try to change the bulbs by going in through the headlight opening.
One other catch is that the lights have to be on to keep the headlights up, and the bulbs will be HOT.
The correct way, and less painful way, is to remove the access panel below the light assembly. The opening is large enough to remove the whole assembly, so you will have not problems changing the bulbs. It takes a little longer, but I think it is well worth it.
Old Aug 13, 2009 | 02:00 PM
jrose7004's Avatar
jrose7004
The access panel below is the easiest.
Old Aug 13, 2009 | 03:09 PM
cdkcorvette7's Avatar
cdkcorvette7
If you don't want to jack the car up, you can go in through the top. I'd suggest loosening the entire headlight assembly to give yourself room to work. If you have even average sized arms, it'll be a tight fit through there with the assembly in place.
Old Aug 29, 2009 | 09:31 PM
KorbenDallas's Avatar
KorbenDallas
I just replaced mine through the top. I removed the black headlight shroud and had enough room for the task. Be mindful of fragile bulb glass; mine broke removing the old one but luckily I didn't get cut.
To Front turn signal out...
