Help! Help! help! ASAP! one quick question will save the day!
Old Aug 13, 2009 | 12:26 AM
rockgoped's Avatar
rockgoped
Default Help! Help! help! ASAP! one quick question will save the day!
hey guys, how do you remove the hydraulic line from the master clylinder? were the black plastic unit actually meets the line. here is a picture. im talking about the oem unit above the after market one. need my car back guys! any help would seriously help. been trying to fix this for a week and i cant figure it out. i dont want to cause anymore damage.
http://www.pbase.com/callaway/image/109345534
Old Aug 13, 2009 | 12:29 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Cut it at the base of where it plugs in to the master.
Old Aug 13, 2009 | 12:37 AM
lucky131969's Avatar
lucky131969
If I'm not mistaken, there should be a roll pin that needs to be driven out with a drift, and then the line will pull free.
Old Aug 13, 2009 | 12:43 AM
rockgoped's Avatar
rockgoped
i pulled the pin out, but it seems to not want to come apart.
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I wasn't sure if he was talking about the resevoir line ? as he showed a picture of the stock and TIK master units. Ithought he was doing a swap ?
Old Aug 13, 2009 | 12:44 AM
rockgoped's Avatar
rockgoped
how do i reconnect the line to the new master if i cut it?
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Why would you want to pull it apart ?
Old Aug 13, 2009 | 12:46 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
You need to explain what you're trying to do ? I thought you were doing a master upgrade to the TIK unit.
Old Aug 13, 2009 | 02:32 AM
slothy's Avatar
slothy
ya, if your installing a tick master u don't need the master line, if you are doing a slave swap from monster there is a split pin you need to bang out of the slave and xfer line to new slave
if your trying to disconnect the master follow the line and you will see a quick disconnect - use a line disconnect tool to pull it apart.
Old Aug 13, 2009 | 03:42 PM
rockgoped's Avatar
rockgoped
im swaping for a new master cylinder. i want to disconnect the line and the cylinder because the new one did not come with a line, just the new master cylinder. just bang it out then huh?
Old Aug 13, 2009 | 03:57 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Or better yet, I have a like new one with 20 miles on it $75 shipped to your door complete with line.
Old Aug 13, 2009 | 08:07 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Where did you get the master cylinder from? If a GM part it should have came with the hose.
Old Aug 13, 2009 | 08:54 PM
SYCLONE2910's Avatar
SYCLONE2910
If that is a picture you took it has the line you need with it. If it isn't the picture you took just ignore me
Old Aug 13, 2009 | 09:02 PM
lucky131969
Maybe I'm losing my marbles here, but I could not be more confused on what you are trying to accomplish. Based on your pic, you have the old stock master with the hard line still attached, and a tick adjustable master cylinder, that has an AN fitting, and the line that connects to it and the quick disconnect.
So what is the problem?
Old Aug 13, 2009 | 10:55 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Old Aug 14, 2009 | 02:06 AM
rockgoped's Avatar
rockgoped
lol. i was attaching the new master cylinder to the old line. i knocked out the pin and got everything together. the new master feels so nice compared to the old one. feels like a new car! (97)
thanks for the replies!!!
To Help! Help! help! ASAP! one quick question will save the day!
