1999 passenger headlight problem
Old Aug 13, 2009 | 08:20 PM
rjm5's Avatar
rjm5
Default 1999 passenger headlight problem
I have a 99 with a passenger headlight that works eradically, sometimes goes up and down then stops altogether usually stops open, I manually close it and it will raise and do it again. is it the motor or a relay or something else?? Jim
Old Aug 13, 2009 | 09:42 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
You'll probably find the plastic gear inside is done and needs to be replaced. There are brass ones available. There are other possibilities too, but look at the gear first.
Old Aug 14, 2009 | 04:47 PM
rjm5's Avatar
rjm5
Thank you so much for the reply; I did however pull the motor on the passanger side light and the plastic gear is ok. Do you have other suggestions? the drivers side works perfect. I really appreciate it. Jim
Old Aug 14, 2009 | 05:25 PM
wildbadbill's Avatar
wildbadbill
when you say the gear is ok -check not just the outside teeth but also the "cross" inside the wheel.This is where the metal piece catches and rotates the headlamp.
Old Aug 14, 2009 | 08:13 PM
dgrant3830's Avatar
dgrant3830
There are only a couple of components in the headlamp system The headlamp switch itself which has a pretty bad failure rate. Also the headlamp controller itself, mounted on the right forward frame rail and finally, the headlamp motor's themselves. Usually when the controller fails, its a case of the lights being on, but are in the down position and most all other failures other than the gears stripping out, the headlamp switch is the cause.
Old Aug 14, 2009 | 10:03 PM
rjm5's Avatar
rjm5
Wow, thanks for the quick response; I will inspect the inside gear and switch.
To 1999 passenger headlight problem
