Harmonic Balancer Issue...?
Old Aug 14, 2009 | 06:36 PM
gmg7's Avatar
gmg7
Default Harmonic Balancer Issue...?
Hey all, I recently had a mechanic friend of mine take a look at my 2001 C5's engine - just for safety purposes. Much to my suprise (bc i was assured that the dealer had all mechanical issues checked) he noticed something he called "peculiar". He then showed me how my harmonic balancer was "wobbly" at idle and acceleration. I've not noticed any oil drippings or major performance issues. Is this a common thing? How do you all suggest I remedy the problem (if it is a problem)? The dealer offers a 3 month 3k mile warranty....please advise. Thanks!
Old Aug 14, 2009 | 06:58 PM
dougbfresh's Avatar
dougbfresh
Common problem solved with aftermarket balancer. Search for harmonic Balancer or wobbly balancer, you'll see all the posts.
Old Aug 14, 2009 | 08:32 PM
gmg7's Avatar
gmg7
thank you sir! i thought i had searched it before, apparently not. common problem - hopefully easily resolved. thanks, again.
Old Aug 14, 2009 | 08:50 PM
dougbfresh's Avatar
dougbfresh
Not too easy, steering rack has to come out to replace the balancer.
Old Aug 14, 2009 | 09:19 PM
clif's Avatar
clif
St. Jude Donor '09-'10
Yep... I had the same issue. I got mine replaced with a nice aftermarket balancer. Just search the forum for all the info you need, including how to replace it!
Old Aug 15, 2009 | 01:10 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Mine failed due to seal failure. Got a POWERBOND to replace it!
BAD HUB Sealing surface!
POWER BOND PULLEY! 25% ubderdrive
BC
To Harmonic Balancer Issue...?
