Electrical Problem
Old Aug 13, 2009 | 09:15 PM
Crownline93's Avatar
Crownline93
4th Gear
Default Electrical Problem
I have a new problem with my 2000 Coup. Tail Lights, Dash Lights, Fog Lights will not work with the steering colum switch. They do work when I hit the Unlock on the KeyBob. Fuses check out OK. Sooo, sounds like the light switch? Any advise on Light switch replacement? Thanks, Paul in Seattle.
Old Aug 13, 2009 | 09:39 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
It probably is the headlamp switch or also called the multifunction switch. They seem to have a fairly high failure rate overall.
