The big red wire on the back of the alternator (BATT TERMINAL) goes to the STARTER SOLENOID,, and from there to the POSITIVE battery terminal. MAKE SURE that the wiring at the starter solenoid is clean and tight.
Measure DCV between the positive battery terminal to the BATT terminal on the back of the alternator. The reading should theoretically be ZERO. The more voltage you see the worse the connection (VOLTAGE DROP) is. Your goal is zero. Check that out before you go crazy replacing stuff. Your reading between the two points so place the meter leads on those two points.
BC
BC
Measure DCV between the positive battery terminal to the BATT terminal on the back of the alternator. The reading should threoreticaly be ZERO. The more voltage you see the worse the connection (VOLTAGE DROP) is. Your goal is zero. Check that out before you go crazy replacing stuff. Your reading between the two points so place the meter leads on those two points.
BC
BC
Right befefore you posted this, i noticed that one of the wires on the back of the starter was roasted, and showing open wire. Do you think I should just replace the entire wire, or splice in a new piece.
Which wire? What color is it? Before replacing, you need to determine the reason why is fried. Is the terminal loose...resulting in a high resistance connection..and subsequently, heat? Direct short? etc.
100% Correct! Heres a pic of the starter with wires:
The wires just don't normally burn up. If it were me,,,,I would replace the wire. There not that long. Its got to supply full alternator current to the battery. Just fix it correctly and you wont/shouldn't get the charging system fault. Thats what id causing it.
As mentioned already, a lose wire will essentially turn itself into a small heater circuit, heating up to the point that it cooks the wire and anything else with it. Dirty or corroded connections do the same thing.
In that pic up there, it's the orangeish wire right under the red wire. The wire had some damage from rubbing against the block I guess. The insulation was removed in some areas, and the core seemed to be "broken" at one spot. I attached a new piece of 8 gauge wire to it, tightened it back up.
I swore it would fix the problem but it didn't.
I've traced the alt-battery and battery-starter wire and they were fine.
How did you attach the repair wire???
What is the voltage on the BATT terminal on the rear of the alternator with the engine OFF and when the engine is ON??
Please post the values.
What do the other wires on the starter look like?
Is there battery voltage on the red wire PIN D in the connector on the alternator???
I really appreciate the help. I don't have a multimeter, but I will pick one up in the morning.
Also, something strange- I had a low oil light last week. I added some oil (it was a little low), then today I changed it. When i started it up earlier, i had a low oil light, but full oil. It keeps flashing it at me, even though it's not low.
I used a female-female butt connector and also soldered the wires. Wrapped in all-weather electrical tape and used a heat sleeve on it.
The wires on the starter all look fine now that i've fixed that one.
Found something else: The sensor that connects right where the oil filter screws in, has burn marks on the wires and some of the core is showing on both wires.
Is this the oil level sensor? this will fix my "low oil" light i bet. I hope i can fix it without removing the header.
That is the oil temp sensor, the oil level is on the right side rear. Unfortunately, not that you have found something disconnected, one cannot not help but wonder what else was missed. Better give everything a good visual inspection.
