why does?
Old Aug 17, 2009 | 09:32 PM
260B4U's Avatar
260B4U
Default why does?
why does my drivers side turn signal keep popping ?
Old Aug 17, 2009 | 09:37 PM
Oldvetter's Avatar
Oldvetter
Your light has a hole in it, it allows water to hit the hot bulb and break it.
You can fix it with some sealant. Remove it and fix it.
Old Aug 17, 2009 | 10:10 PM
260B4U's Avatar
260B4U
ill check it closer but it doesnt seem to leak or have a crack or hole in it
Old Aug 17, 2009 | 11:21 PM
mcgilles's Avatar
mcgilles
you probably won't be able to see it until you get the lens out.
among other reasons why you should disable your DRLs...the DRLs on C5s keep your turn signal bulbs lit in bright mode all day long. the heat from the bulbs is well known to melt and eventually cause a crack in the turn signal housing directly above the bulb. once that happens water will enter as soon as it rains and hit the hot bulb causing it to go.
seal the hole, replace your signal lenses with some nice clear ones if the damage is too bad and disable the DRLs or it will just happen again.
Old Aug 17, 2009 | 11:55 PM
lionelhutz's Avatar
lionelhutz
Yup, look right above the bulb. You can see it from around the headlight. There is a round hole in a gray piece above the white lens. It burns through right there.
To fix it just cover it with silicone or put in Depo corner lights and then install LED's to keep it from happening again.
Peter
Old Aug 18, 2009 | 12:50 AM
DeeGee's Avatar
DeeGee
This might help when you get round to pulling the light unit
Document ID# 655625
2002 Chevrolet Corvette
________________________________________
Park/Turn Signal/Side Marker Lamp Replacement
Removal Procedure
1. Raise and support the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
2. Remove the front fascia lower closeout panel.
3. Release the brake caliper cooling duct from the front fascia, and position the duct aside.
4. Remove the front turn signal lamp bracket retaining spring from the lamp bracket.
5. Remove the lamp bracket retaining spring from the front fascia.
6. Remove the front turn signal lamp bracket retaining screws.
7. Disconnect the sockets from the lamp.
8. Remove the lamp, with the bracket, from the vehicle.
9. Remove the lamp to bracket retaining screws.
10. Remove the lamp from the bracket.
Installation Procedure
1. Install the front park/turn signal and sidemarker lamp into position on the front turn signal lamp bracket.
Notice
Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
2. Install the front park/turn signal and sidemarker lamp to bracket retaining screws.
Tighten
Tighten the front park/turn signal and sidemarker lamp to bracket retaining screws to 2 N•m (18 lb in).
3. Install the sockets to the lamp.
4. Install the lamp, with the bracket, to the front fascia.
5. Align the lamp to the opening in the front fascia and hold the lamp firmly in place against the fascia, while installing the front turn signal lamp bracket retaining screws.
Tighten
Tighten the front turn signal lamp bracket retaining screws to 3 N•m (27 lb in).
6. Install the lamp bracket retaining spring to the front fascia.
7. Install the front turn signal lamp bracket retaining spring to the lamp bracket.
8. Position the brake caliper cooling duct to the front fascia and press the duct toward the fascia to secure.
9. Install the front fascia lower closeout panel. Refer to Close Out Panel - Front Bumper Fascia Lower in Bumpers.
To why does?
