New Headers Backfire at Idle Help
Aug 19, 2009 | 03:38 PM
I'm a DUMBASS
Quote:
Originally Posted by
vsocks1
Hope you get it figured out....these kind of problems can be real frustrating.
Pulled the pass side exhaust gasket . NO sign of leaking. So while I'm waiting around I decide to check something else.....
I had all 8 of these out yesterday checked them all. Used dielectric grease when I re-installed the wires.
They were all light brown and exactly the same in color.
Should have inspected the insulator better.
Think maybe this is the problem? Came out of #8
On the way to the parts house.
Aug 19, 2009 | 03:44 PM
Uggghh....I didn't even suggest it considering how many installs you've already done........at least it is simple...
Aug 19, 2009 | 03:57 PM
lucky131969
Rule #1 Look for the simple things 1st.
Because the plugs were are burning even I did not even think. Obviously
Aug 19, 2009 | 08:17 PM
Running Perfect and hauls A**.
Aug 20, 2009 | 12:01 AM
Aug 20, 2009 | 05:12 PM
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
I found my cracked plug today. Thanks to P0303 I was able to track it down to #3. Cracked in 2 places.
Aug 20, 2009 | 06:48 PM
Jhonathan_W
And my son's wasn't even throwing any codes. Plus all I could see Data Logging with HP was erratic O2.
Aug 20, 2009 | 06:50 PM
Thanks for posting up. I thought I checked the plugs 2x, but missed this one somehow. I now know the difference between cylinders 3 and 5.
Your post made me look again.
Dang i gotta check mine, when i installed headers, install plugs and wires at the same time, and i get back fire a lot, u know whne u decelerate coming to stop, it back fires and popping sound.
Is that popping sound u referring to or it really backfires without revving gas?
Mine pops only when iam decelerating gas..
Aug 20, 2009 | 07:05 PM
Mine popped just sitting there idling. It first idled smooth then 1 pop 2 pop then back to back.
I haven't road tested it yet.
From what I've read popping on decel is normal.
2007 ,
backfire ,
backfires ,
backfiring ,
burned ,
c5 ,
car ,
chevy ,
cigarette ,
corvette ,
decel ,
exhaust ,
header ,
hptuners ,
idle ,
low
