2000 LS1 cam specs
Old Aug 18, 2009 | 01:27 AM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Default 2000 LS1 cam specs
I have seen different information in various threads posted regarding the cam specs for the 2000 LS1. I have one parts sheets (of which I do not remember where I got it) that shows only the 2000 model year with a 500/500 lift/ 115.5 LSA cam. The years before and after have less lift.
Anyone have any definitve information on the subject.
Thanks.
Bill
Old Aug 18, 2009 | 02:57 AM
Last C5's Avatar
Last C5
Y Cars (Vettes) LS1
1997-99-----.479/.472 lift-------207/199 duration--------117 separation
2000--------.500/.500----------209/198----------------115.5
2001-03-----.479/467----------207/196----------------116
F Cars (Camaros)LS1
1998-00-----.500/.500---------209/198----------------119.5
2001-02-----.479/.467---------209/198----------------116
Old Aug 18, 2009 | 11:06 AM
Blown427conv's Avatar
Blown427conv
I did lots of searching when I R&Rd the engine in my 2000 also with a 99 F-body engine and found the same info. I also measured the cams out of both and checked the cam part numbers and found that the f-body cam was the same specs as the listed Corvettes for that year with .479 lift. I wound up going with the F-body cam and can't feel any difference in power. The cams are all so close in size that I think you will not be able to tell a seat of the pants difference.
Old Aug 18, 2009 | 09:00 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
Thanks.
Bill
Put a big boy cam in that car
Old Aug 18, 2009 | 11:04 PM
happa's Avatar
happa
Old Aug 19, 2009 | 06:49 AM
AU N EGL's Avatar
AU N EGL
This is what I have found
2001+
LS1 198/208 500/500 116
LS6 207/217 525/525 116
Other GM cams
HotCam 219/228 525/525 112
LS2 204/211 525/525 116
ASA 226/236 525/525 110
CupCam 239/251 570/570 106
Old Aug 19, 2009 | 09:41 AM
jovette's Avatar
jovette
C5 camshafts:
'97-'99 LS1 .479/.472 lift, 207/199 duration, 117 Lobe Separation Angle
'00 LS1 .500/.500 lift, 209/198 duration, 115.5 LSA
'01-04 LS1 .479/.467 lift, 207/196 duration, 116 LSA
'01 LS6 .525/.525 lift, 211/204 duration, 116 LSA
'02-04 LS6 .551/.555 lift, 218/204 duration, 117.5 LSA
2000 camshaft was given more lift and duration to compensate for the inclusion of pre/pup cats on California and north eastern United States sold vettes to comply with emissions requirements. All '00 LS1s got the larger camshafts, but only those sold for delivery in California or north eastern USA, got the hp robbing pre/pup cats installed. This means the non-pre/pup cat '00 C5s got some "free" additional hp!...maybe 5hp?
"01 LS1s, got the larger volume LS6 intake manifold, and better flowing, but heavier cast iron exhaust manifolds, larger MAF, and better flowing air intake box, but were then equipped with the same pre/pup cats the '00 California and NE USA sold cars got, as well as the smaller camshaft, similar to that of the 97-99 LS1. All of these changes combined for a net increase of 5hp, and 10 lbs.(auto) and 25 lbs. (manual) of torque.
Above information taken from articles written by Christopher P. Endres, and Hib Halverson
Old Aug 19, 2009 | 05:14 PM
11sec_C5Z51's Avatar
11sec_C5Z51
Originally Posted by Last C5
Y Cars (Vettes) LS1
F Cars (Camaros)LS1
Great Info!!! I've been looking for this
Old Aug 20, 2009 | 08:17 AM
Blown427conv
Originally Posted by jovette
C5 camshafts:
This is the info I came up with when I did the research and actually measured my 2000 C5 cam and a 99 F-body cam that came in an engine I bought to replace mine with.
To 2000 LS1 cam specs
