Removing column lock bypass question
Old Aug 18, 2009 | 09:28 AM
ssdeuce's Avatar
ssdeuce
Default Removing column lock bypass question
I have a 2004 Z06 that I installed the column lock bypass when I bought the car just to be safe. Now I need to have my steering wheel position sensor replaced and got to thinking. Does the bypass need to be removed before I take the car to the dealer to have the sensor replaced? I did a search and had no luck. Thanks for any help.
Old Aug 18, 2009 | 03:00 PM
Mr. Clean's Avatar
Mr. Clean
I also installed the CLB when I first purchased my 2001 convertible. About two years afterwards, I had to have the steering wheel position sensor replaced. I did not remove the CLB and had no problem with the dealer doing the job under warranty.
Old Aug 18, 2009 | 11:11 PM
ssdeuce's Avatar
ssdeuce
Good to know. I was worried about it since the column has to come out. Thanks for your help.
To Removing column lock bypass question
