Problem with passenger side door unlocking with remote or switch?
Old Feb 17, 2002 | 11:06 PM
zero2sixtyin4.5's Avatar
zero2sixtyin4.5
Default Problem with passenger side door unlocking with remote or switch?
It's like those times when you can't find the tv remote. You are sitting 3 feet from the tv and you spend 4 hours looking for the remote! :D I have had problems with the passenger side door not unlocking right away with either the remote or the switch on the door. Has anyone encountered that problem? If so, how did you fix it? :(
Old Feb 18, 2002 | 12:54 AM
Colorado's Avatar
Colorado
Default Re: Problem with passenger side door unlocking with remote or switch? (zero2sixtyin4.5)
Use the option button on the dash to set how it works. You probably have it set where first press unlocks drivers door, second unlocks passenger door.
Old Feb 18, 2002 | 01:02 AM
tomdcarguy's Avatar
tomdcarguy
From: A.M.R. Pound for Pound-Fastest Stock Bottom LS1 9.1x 10psi
Most likely a door control module...On board relay failing.... quite common. Not that big of a deal.
Old Feb 18, 2002 | 09:12 AM
br's Avatar
br
Default Re: Problem with passenger side door unlocking with remote or switch? (tomdcarguy)
Make sure the wires are connected to the switch plate. The switchplate cover on the passenger side is removed by lifting the top first. Then check the connections on the bottom.
To Problem with passenger side door unlocking with remote or switch?
