help with my window adj 98 conv
Old Feb 18, 2002 | 03:08 AM
corvettepace's Avatar
corvettepace
Default help with my window adj 98 conv
can some one tell me how to stop my window from catching on outside of vert top i have a 98 conv. pace car it just started doing this in the past 6 months also I can see where window has scrubbed against top. it is catching at the rear,top side now on both doors started out just on driver door.If I close the door with the top corner of the door it does not catch do I need to adj window or adj conv top ? :smash:
Old Feb 18, 2002 | 03:12 AM
corvettepace
Default Re: help with my window adj 98 conv (corvettepace)
[IMG][/IMG] http://photos.yahoo.com/bc/corvettep...c=ph%26.view=t :reddevil
[Modified by corvettepace, 12:30 AM 2/19/2002]
Old Feb 18, 2002 | 06:04 AM
Drop_Top_Dave's Avatar
Drop_Top_Dave
Kid Rock Fan
Cruise-In IV Veteran
Hmmm, haven't had the problem with my '98. Great! Something else to worry about!! :rolleyes:
[Modified by Drop_Top_Dave, 5:06 AM 2/18/2002]
Old Feb 18, 2002 | 09:04 AM
br's Avatar
br
Window regulator adjustment would be the correct way. You would have to remove the trim panel for this one. Loosen the regulator to glass clamps and move the glass foreward 1mm at a time until it does not hit. You can gage this by using the black line on the rear of the glass right at the glass clamp. I have found 1 mm is almost always enough. Make sure to retorque the clamp bolt to 16N. I would first check your dealer for any bulletins.
To help with my window adj 98 conv
