Engine Stalls
Old Aug 20, 2009 | 09:22 PM
mikeL82's Avatar
mikeL82
Default Engine Stalls
1999 automatic. Last drove the car on Friday. No problems. Went to start it tonight, battery dead. Just a clicking sound. Got it started with a jump starter. Waited about two minutes, put it in reverse, backed up 3 feet, it stalled. Started right up, put it in reverse, stalled again. Connected to a floor model charger for about 1 hour, same thing, stalled when put in gear. Any help would be appreciated.
Old Aug 20, 2009 | 09:41 PM
lucky131969's Avatar
lucky131969
codes?
Old Aug 20, 2009 | 09:45 PM
Blown427conv's Avatar
Blown427conv
Sounds like you have activated the security system that shuts it off after 2MPH. Do a search on it and see what you think. Good luck.
Old Aug 20, 2009 | 09:50 PM
mikeL82's Avatar
mikeL82
Originally Posted by lucky131969
codes?
No codes. I checked.
Old Aug 22, 2009 | 09:41 PM
mikeL82's Avatar
mikeL82
After spending a lot of time reading many threads on this issue, The
2mph problem went away when I charged the battery to full charge.
Now the issue is why did the battery go dead.
Is it still true that you have a short if you disconnect the possitive battery terminal and connect a test light, one end to the cable and one end to the post and the test light lights up?
Old Aug 23, 2009 | 01:36 PM
Blown427conv
I believe so., Then you can start pulling fuses till it goes out to isolate the system with a draw.
Old Aug 23, 2009 | 01:38 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
you can get an amp meter as well to connect there. i believe that test will work, though. it may pull a little current at first then should dwindle down to almost nothing.
my old car used to do that when the pellet on the key didn't connect correctly for some reason.
To Engine Stalls
