2002 Z06 code hepl PLEASE !!
Old Aug 24, 2009 | 08:45 PM
yellow2002z06's Avatar
yellow2002z06
3rd Gear
Default 2002 Z06 code hepl PLEASE !!
AO-LDCM codes popped up today. They are B2282, B2284, B2262, and U1064. Best I can tell is that they are related to the Left Door Module. I start the car and get a steering lock column error, but the column is NOT locked and it will crank, but when I start to drive, the car stalls. If I replace the door module, will this fix the problem? Thanks in advance for any input.
Old Aug 24, 2009 | 08:53 PM
meadowz06's Avatar
meadowz06
St. Jude Donor '09 and '13
You have the dreaded column lock. Here is what you do. Take the car to your chevrolet dealership. Tell them to do the SECOND recall. It will fix all of your problems. And it is FREE. They cannot charge you for the fix. I just had mine done last week, free of charge. What they will do is remove the locking plate and install a new wiring harness in the column.
No big deal. Relax.
Old Aug 24, 2009 | 08:58 PM
yellow2002z06
3rd Gear
I thought the Column Lock issue threw a different set of codes. My codes are related to the Left Door Control Module. Also, does it matter to the Chevy Dealer that the car is 7 years old and I am not the original owner?
Old Aug 24, 2009 | 09:07 PM
meadowz06's Avatar
meadowz06
Your codes are tied in with the column lock problem. And your car is covered under the recall. My car is a 99 model. Just take the car to the dealer and they will fix the car for free. Good luck.
Old Aug 24, 2009 | 09:08 PM
meadowz06's Avatar
meadowz06
http://forums.corvetteforum.com/c5-t...ky-please.html
Old Aug 24, 2009 | 09:14 PM
yellow2002z06
3rd Gear
Cool. Thanks.
To 2002 Z06 code hepl PLEASE !!
