What's the Diff?
I have someone wanting to trade me a fresh rebuilt 3:73 geared rear end for my used 3:42 from my 2003 Z, strait across. Sounds like a hell of a deal yeah? Well as the story unfolds I find that the gears are new but the person who rebuilt it figured these are just like any other rear end and has this one set so tight that you can't even turn the gears by hand. So this one will have to be gone through and set up properly. That's issue #1
Issue #2 is the case is a single rib not a 3 rib like mine. Owner of the diff says it supposedly came from an 01Z. Not wanting to have to "set up" 2 rear ends swapping cases may not be an option unless the 1 rib owner wants to pay the extra.
So far I have only seen the single rib cases come out of auto cars not any 6 speeds and they were 2:73 gears. The owner of the rebuilt diff is in a 2004 auto car with 2:73.
Now to my question
Was the single rib to the 3 rib case a model year change over or does it have to do with only 2:73/3:15 rears have them?
My plan may be to use this guys case if it's a 3 rib that comes out of his car, I'm really hoping it is.
Any help with this info would be greatly appreciated.
Also on a side note/question.
Does anyone know if the stock C6 2 piece short shaft is any stronger than the stock C5, and do they interchange?
I'd stay away from that messed up diff.
Buy one from a shop that stands behind their work and is very familiar with these rear ends. You'll thank me when you don't have to pull it apart a second time, lol.
Let's hope the info is accurate.
http://forums.corvetteforum.com/c5-t...dependant.html
As for standing behind their work? Well a friend of mine and I will be standing behind our own work and that's good enough for me.
