Steering column lock
Old Aug 26, 2009 | 10:51 AM
Keppah's Avatar
Keppah
Default Steering column lock
Going to install CLB.(had steering column lock code and fuel shutoff is set at 2mph& K harness GM put in failed)I have been doing some research and some Corvette owners seem to think installing CLB will cause BCM failure(or other problems).Does anybody have any info about this?Would like to know before I install CLB.
Old Aug 26, 2009 | 12:13 PM
timemender's Avatar
timemender
I have read many times on this forum that some 1997 & 1998 C5’s do have trouble with the CLB functioning properly.
Contact “Corvettes Of Houston” at (281) 821-1222 they are a forum sponsor/vendor. They will have the answer for you.
Old Aug 26, 2009 | 02:27 PM
Keppah's Avatar
Keppah
So if I install CLB on a 1997 Corvette(Automatic)I should not have any more promlems right.Should I change fuel setting?Is the extra RELAY only installed on Corvettes with standard Transmission?Thanks for all your help.Waiting for CLB from Corvettes of Houston should be here this week.
Old Aug 26, 2009 | 03:16 PM
Keppah's Avatar
Keppah
Thanks again 8VETTE7.Will see what happens when I install CLB will pray that it works.Thanks again for your info and quick reply.
Old Aug 27, 2009 | 12:34 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
I have had some trouble with the CLB in my 97. I get the pull key quite a bit and once in a while the service column lock. I just tuned out the fuel cutoff so it will still run normal. Just be sure the lock plate is removed if you have the fuel cutoff tuned out. I used EFI Live. I could probably tune yours out if you wanted, just have to send me the pcm. I would just have to plug your pcm in to my vette to do it, no big deal really
Old Aug 27, 2009 | 11:27 AM
Keppah's Avatar
Keppah
Thanks for offer.Long way to send PCM.Installed CLB last night will see what happens.There is a place about 3 hours away they want $400.00 dollars to do fuel shut off that seems to be high but I think they do a complete tune.Anyway thanks for reply and offer.
Old Aug 27, 2009 | 03:38 PM
Keppah's Avatar
Keppah
For the $400.00 it is a full tune.They said they just couldn't change fuel shut off setting would have do to a full tune.What is involved in a full tune?Is it worth getting done?Do you recommend doing a full tune?
Old Aug 27, 2009 | 04:15 PM
Keppah's Avatar
Keppah
Thanks will not do tune for now.Installed CLB seems to work so far.Thanks for you info.
Old Aug 27, 2009 | 06:16 PM
mvvette97's Avatar
mvvette97
That's a bit much money. With EFI Live I can tune 97-98 cars for free. If ya ever decide you want it done just let me know, I can also change other things to help the car perform better also.
To Steering column lock
