Breaking wheel studs
Aug 26, 2009 | 04:18 PM
I have I-forged rims on my Z and have broke 3 different wheel studs since I have had the rims on my car. Any ideas to why this may be happening?
Aug 26, 2009 | 04:19 PM
how are you breaking them? ie tightening, driving, hard launches?
Aug 26, 2009 | 04:32 PM
Driving under normal conditions
Aug 26, 2009 | 07:54 PM
Are the wheels made specifically for the GM bolt pattern (5x120.6mm)?
What torque value do you use to tighten the lugs?
Aug 26, 2009 | 08:32 PM
Give Randy a call at Doug Rippie Motorsports (forum sponsor) and get some of their 90,000 psi studs. I used them when I put the big brakes on my vert.
Aug 26, 2009 | 08:42 PM
Aug 27, 2009 | 12:00 PM
The only time I have seen broken studs is road racing or over torquing.
Aug 30, 2009 | 03:08 PM
Thanks for the responses, would being the incorrect offset cause studs to break off?
Aug 30, 2009 | 07:01 PM
St. Jude Donor '08-'09-'10
I wouldn't think the offset would cause breaking studs but if the wheels aren't hubcentric I'd think you would have a problem.
Aug 30, 2009 | 09:21 PM
Quote:
Originally Posted by
AU N EGL
Over torqued ?
100 lb ft
MAX 100 lbs. some idoit did 130
