Help.. Changed brake calipers and now having issues.
Old Aug 26, 2009 | 07:58 PM
JeremiahsC5's Avatar
JeremiahsC5
Default Help.. Changed brake calipers and now having issues.
Like I said. I just changed my old brake calipers for a new set of z06 calipers. Bled them and went to pull off and peddle went to the floor. So I pulled back in and bled them again. Same thing happend. So I took it for a drive and found that if I gently push on the brake peddle it will go to the floor. If I tap it a few times before pushing it hard it will build up pressure and brake properly.
Thanks in advance.
Old Aug 26, 2009 | 08:02 PM
Greg_E's Avatar
Greg_E
Did you put them on the correct side? Bleeder nut has to be at the top. A common mistake.
Old Aug 26, 2009 | 08:04 PM
JeremiahsC5
No I did not. I love the forum... Will change and see what happens
Old Aug 26, 2009 | 08:05 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
When you had the calipers off,,,,,,,,did the master cylinder go dry by chance????????
If it did,,,,your going to need to bleed the master cylinder FIRST and then the claipers.
Old Aug 26, 2009 | 08:19 PM
Patches's Avatar
Patches
Exactly. The air in the caliper rises to the top and can only escape if the bleed port is facing upward and is on top.
Old Aug 26, 2009 | 08:28 PM
byronhunter's Avatar
byronhunter
Will change and see what happens:o We know what will happen, you're good to go, if the master don't go dry as Bill says.
Old Aug 26, 2009 | 08:29 PM
NeutronVette's Avatar
NeutronVette
Old Aug 26, 2009 | 08:53 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Greg
WOW! Very good catch and recommendation!
When someone post a problem like this one, sometimes I fail to take EVERYTHING that can go wrong into consideration. To me, that problem (caliper mounted on the wrong side) wouldnt happen because I know that the bleeders need to be up.
Guess I need to be a little more open minded.
BC
Old Aug 26, 2009 | 10:07 PM
JeremiahsC5
Problem solved. Good call Greg_E. Your the man.
Old Aug 26, 2009 | 10:39 PM
lucky131969's Avatar
lucky131969
I tried to get as much out that I could with a baster. I am pretty sure there was still some in the lower part of the master cylinder.
Have a service manual by chance?
To Help.. Changed brake calipers and now having issues.
