The last three times I have driven the car it has thrown these codes while continuing to run without problems; all reset but came back after about an hour of driving. Is something happening or about to happen?
History and Current: P0111 and it is not on my list of codes.
History only: P0113 Intake Air temperature (IAT) Sensor Circuit High Voltage -B
B0367 Right Actuator Feedback Open
Good question, I can't find applicable for any year C5
We've been seeing several codes lately from various owners that aren't showing up in the code lists... wonder what's going on with that?
I'm not sure, but the last few times, the OP has not responded back. The most recent was a guy who posted an F-body code, but never responded when I inquired...
Some codes are year specific....either dropped from the 97-98 years, or added later...
Well, they have not repeated for the last two days but I am just driving back an forth to work, about 15 minutes each way, and I have not been using the AC.
So it sounds like the IAT is having a problem. Buy a new one and see what happens. Might check the wires first and make sure you have clean connections before buying the new IAT.
