need help - PASS-key detection circuit??
Old Aug 30, 2009 | 02:18 PM
yamahajo's Avatar
yamahajo
Cruise-In 9-10-11 Veteran
St. Jude Donor '08-'09-'10,-'13
I believe in the Beer Fairy
Default need help - PASS-key detection circuit??
...and yes I did a search.
Replaced the ignition in my car on Friday. Now the security light won't go off. Pulled codes only to see 'PASS-key detection circuit'. ( B2721 )
Any thought on what exactly this means? And how to fix it?
Car starts up just fine, but now I've got this code and another pesky light on the dash.
Old Aug 31, 2009 | 06:55 AM
yamahajo's Avatar
yamahajo
bump - no one have this issue come up before?
Old Aug 31, 2009 | 07:32 AM
dougbfresh's Avatar
dougbfresh
Maybe try the relearn sequence of the key to the BCM. I posted this about a week or so again-try "Advanced Search". It takes about 30 minutes.
Old Aug 31, 2009 | 08:59 AM
yamahajo's Avatar
yamahajo
Tried that yesterday with no luck.
Old Aug 31, 2009 | 09:01 AM
dougbfresh's Avatar
dougbfresh
Sure you put the switch in right? No pinched wires?
Old Aug 31, 2009 | 09:23 AM
yamahajo's Avatar
yamahajo
Ignition can only go in one way. When the last ignition gave out, it also gave me the security light. So it was something that frazzled when the last one went.
Old Aug 31, 2009 | 10:07 AM
dougbfresh's Avatar
dougbfresh
Maybe disconnect the battery for a short while?? Do you have a different key to try?
Old Aug 31, 2009 | 11:22 AM
yamahajo's Avatar
yamahajo
I can try the battery - no other keys yet either. Need to get another made.
Old Aug 31, 2009 | 11:41 AM
Dixievet's Avatar
Dixievet
CI 7, 9, 10 & 11 Veteran
Old Aug 31, 2009 | 12:59 PM
yamahajo's Avatar
yamahajo
Originally Posted by Dixievet
thanks.
Old Aug 31, 2009 | 03:16 PM
yamahajo's Avatar
yamahajo
Dealership basically told me that without a new ignition in the exact pass code # it won't go away.
one step closer to a c6......
Old Aug 31, 2009 | 04:25 PM
dougbfresh's Avatar
dougbfresh
??? I don't understand what he's saying here.
Old Aug 31, 2009 | 04:46 PM
yamahajo's Avatar
yamahajo
That little chip in your key ranges from #1-15. I know my car is a 14. The new ignition and key I'm not sure about. But he's saying it's not the same number, which is causing the codes. But my security light was on with the last ignition, the final crank I got out of it before it seized. Maybe had it been replaced with an ignition / key of the same number the codes would clear.
Either way, I'm not spending another $100+ just to get rid of a light. It's just another one to pop up on the dash.
Old Sep 1, 2009 | 08:03 AM
1badf350's Avatar
1badf350
Did you just replace the ignition switch or the whole thing? I'm worried because I just ordered a new switch for mine and I'm hoping this doesn't happen to me when I change it.
Old Sep 2, 2009 | 01:55 PM
yamahajo's Avatar
yamahajo
I replaced the entire cylinder on my car......uses a completely different key now
Old Sep 2, 2009 | 02:13 PM
dougbfresh's Avatar
dougbfresh
That's your problem then, the key resistance is not the same one as what the computer remembers. I don't think the relearn will fix this, I think you need a trip to the dealer for some special time with the TechII.
Old Sep 2, 2009 | 02:26 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
If the BCM doesn't recognize the chip's resistance and it doesn't match what is in memory, the security light should be flashing and the car should not start up. If it is starting under these conditions, then something's been re-wired at the TDR relay. Pull your codes first and report what you find.
To need help - PASS-key detection circuit??
