Headlight Problem
Old Aug 29, 2009 | 09:50 AM
MN/AZ/C5/C6's Avatar
MN/AZ/C5/C6
Default Headlight Problem
I have a '98 C5 that has a headlight switch problem. If the engine is running and I turn the headlight switch on, the headlight doors will not open. However, if the engine is turned off and the ignition switch is in accessory mode, the doors will open and the lights will come on just fine.
Any ideas on what is going on?
Old Sep 16, 2009 | 08:20 PM
MN/AZ/C5/C6
Default Problem Resolved
I thought I should post the resolution to this problem in case another member has a similar problem and reads this thread while searching for a solution.
I searched the forum for headlight problems and found that a couple other members had similar problems that were resolved by tightening the battery terminal connections. I tightened each terminal connection about a quarter of a turn and the problem was fixed.
Sometimes it is really something simple. Once again, this forum provides a wealth of valuable information.
Old Sep 16, 2009 | 09:36 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
hmmm...interesting fix. I had not heard that one before in the case of the headlights, so Thanks for reporting it.
Old Sep 17, 2009 | 09:23 PM
ctimmons's Avatar
ctimmons
2nd Gear
Default Headlight Doesn't Open
I have a 2000 Vette. The driver side headlight will not open. I have been under the hood and turned a **** that seemed to work once or twice. Then it goes back to not opening.
Any suggestions on what I need to have replaced?
Old Sep 17, 2009 | 09:59 PM
dgrant3830's Avatar
dgrant3830
In your case, the gear is probably stripped out therefore you need to replace with a brass one.
Old Sep 20, 2009 | 05:37 PM
ctimmons's Avatar
ctimmons
2nd Gear
Thank you for the info...maybe this is something my boyfriend can change for me. !!
I think I saw this gear on this site are the instructions on here also?
Old Sep 20, 2009 | 11:43 PM
dgrant3830's Avatar
dgrant3830
Its a pretty obvious repair but yes, the instructions should be in here somewhere.
Old Sep 21, 2009 | 12:04 AM
byronhunter's Avatar
byronhunter
Click on this, and go down to post #2.
http://forums.corvetteforum.com/c5-t...with-pics.html
Old Sep 23, 2009 | 06:28 PM
BLUE Y2K's Avatar
BLUE Y2K
My headlights won't turn on if the car is off. Is this normal? They turn on fine and open up when the car is running.
Old Sep 23, 2009 | 09:51 PM
dgrant3830's Avatar
dgrant3830
That's not normal. You should be able to turn them on even though the car is off. If you turn the headlamp switch to the parking lamp position, does the odometer appear in the DIC? If you turn the headlamp switch all the way, do the lamps turn on but not raise?
Old Sep 24, 2009 | 09:01 AM
BLUE Y2K's Avatar
BLUE Y2K
I will have to check it out. I haven't checked to see if the lamps turn on when they don't pop up and I'm not sure on the odometer. It is kind of a pain to have to start the car to wash the lights! They work perfectly when the car is running.
Old Sep 24, 2009 | 11:48 AM
dgrant3830's Avatar
dgrant3830
I'm guessing that your headlamp switch is bad but lets not get too far past this as it was the OP's thread and other's will start to get confused. The OP has resolved his issue.
Old Sep 25, 2009 | 11:21 AM
BLUE Y2K's Avatar
BLUE Y2K
I checked them and now they are working properly. I have only owned the car for about 6 weeks and have not tried to turn them on without the car running for awhile. I did go in and shut off the twilight sentinel a few weeks ago so maybe that had something to do with the way that the lights were working. I am not sure if I have tried to turn the lights on without the car running since I made that change. Thank you for the advice!!
Old Oct 4, 2009 | 01:29 PM
dberry08's Avatar
dberry08
Thanks for the post, I just replaced my battery and now the headlights won't pop up regularly, I'm guessing it's the battery.
To Headlight Problem
