Fuel filter where ?
Old Oct 4, 2009 | 09:05 AM
omegac1's Avatar
omegac1
Default Fuel filter where ?
I am a new 2003 owner with 73k miles. I want to change the fuel filter but after casual look I can not find it. I have had people tell me that its under the metal gas tank shield, some tell me that its in the fuel tank, and others say that I must remove one of the under body fiberglass panels and it moutned to the drivers side frame rail. Can anyone te3ll me where the 03 filter is?
Old Oct 4, 2009 | 09:09 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
driver side up on the frame by rear wheel.
kind of a PITA but if you have a disconnect tool its not to bad you may need to remove it from the mount to get one side undone. Make sure you relieve pressure and cover with a rag so you don't wear to much. Its pretty easy once you see it
Old Oct 4, 2009 | 10:45 AM
lucky131969's Avatar
lucky131969
FFS started in 2003(not sure at what serial number). The OP's filter may be in the tank.
Old Oct 4, 2009 | 11:32 AM
Z06supercharged's Avatar
Z06supercharged
If your 2003 is built after November 25th 2002 with a VIN after 114930 (last six digits) it has the FFS (I call it Fu**ed Fuel System) that is on top of the gas tank accessible only with no replaceable fuel filter. You have to pull the tank out then pull the pump out and again its a non replaceable filter on the pump itself.
Here is how the FSS works and all parts:
http://www.corvetteactioncenter.com/...el+Tank+System
Old Oct 4, 2009 | 11:50 AM
2EZ 2SPD's Avatar
2EZ 2SPD
This is a pic of my 97 fuel filter. I have been told 97 & 98 are here by the back tire drivers side and after 98 they are up under the hood not sure exactly where.
Old Oct 4, 2009 | 11:55 AM
lucky131969
Whoever told you that......stop listening to them......
Old Oct 4, 2009 | 12:07 PM
2EZ 2SPD's Avatar
2EZ 2SPD
OK, I went back looking at old post trying to find it and I couldn't. So fill me in are they all here by the back tire? Did something change in 99 or was I told that wrong as well?
Old Oct 4, 2009 | 01:14 PM
lucky131969
The style of filter changed in 99...moving from a stand alone filter, to a integrated fuel filter/pressure regulator assembly. Prior to 99, the location on the rear right frame rail was the same, but it was a filter only. It then changed again in February of 2003. Here's a portion of the TSB below(already posted by ZO6Supercharged):
Service VME - New FFS Fuel System #PI00918 - (Feb 27, 2003)
Service VME - New FFS fuel system
When servicing the vehicle with the VIN you entered, the following diagnosis might be helpful if the vehicle exhibits the described symptoms.
SERVICE VME
This is a service VME concerning 2003 model year Corvettes and the new FFS fuel system. Starting on November 25, 2002 with vehicle identification number 35111542, the Corvette began using a new fuel system that consists of new tank and fuel line assemblies. This new fuel system will be identified on the service parts identification label during the 2003 model year with the RPO FFS. There are a number of differences between the original design and this system. Technicians should refer to the 2003 model year service information before performing diagnostics or repairs. Care must be taken when ordering service parts to ensure that they are ordered for the correct system.
Old Oct 4, 2009 | 01:18 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
SERVICE VME
Good post! Now I know what FFS stands for...
Old Oct 4, 2009 | 01:31 PM
2EZ 2SPD's Avatar
2EZ 2SPD
SERVICE VME
Thanks for the info if I was given bad info I don't want to repeat it.
Old Oct 4, 2009 | 01:34 PM
Z06supercharged
Yea its fu** fuel system is what it stands for. If I had known about it before I bought my 03 I would have got a 02 instead.
To Fuel filter where ?
