How do you replace daytime running light bulb?
Old Aug 29, 2009 | 11:11 AM
BKbroiler's Avatar
BKbroiler
Default How do you replace daytime running light bulb?
I have an 04 coupe. The pass. side daytime running light is out. Hopefully, it just needs a bulb. I took a quick look and I can't see how to get to it. The owner's manual doesn't address that one. Anybody have any experience with this? Thanks.
Old Aug 29, 2009 | 11:22 AM
NeutronVette's Avatar
NeutronVette
open headlights, turn off lamps while the headlights are still up.
take off black shroud that surrounds light.(three screws I beleive)
remove black plastic shroud.
reach hand inside and down to where the DRL lamp should be.
a quarter turn should pull socket out and pull bulb from the socket.
I've done this at least 10 times.
Old Aug 29, 2009 | 12:24 PM
BKbroiler's Avatar
BKbroiler
Neutronvette - Ok using your route I can get my hand on the socket but I can't get a good enough grip to turn it. That's a tight squeeze. Any other suggestions?
Old Aug 29, 2009 | 12:39 PM
my6thvette's Avatar
my6thvette
Remove the plastic panel under the front bumper. You can then get to it from the bottom.
Old Aug 29, 2009 | 02:59 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
I will add one thing to NeutronVette's instructions that may make the difference for you.
With the headlamps up turn the **** on the passenger one to manually lower the assembly a few inches. This will create a little more space for you to get your hand down there and turn the socket.
Old Aug 29, 2009 | 03:04 PM
BKbroiler's Avatar
BKbroiler
I assume you're talking about the black plastic panel behind the bumper that extends all the way to the top of the radiator accross the front of the car and has the air filter box and tubing connected to it. Wow, that will be quite a project.
How about removing the headlight assembly and reaching down that way?
Old Aug 29, 2009 | 03:25 PM
BKbroiler's Avatar
BKbroiler
I got the socket out finally. To gain some clearance, I removed the threaded hood support bumper near the headlight. Then I had room to reach in far enough to twist the socket out.
Thanks for the suggestions guys.
Old Aug 29, 2009 | 03:48 PM
vettenuts's Avatar
vettenuts
I just push the brake duct back, reach in, remove the bulb socket, pull it out and swap bulb. Reverse to install.
Old Aug 29, 2009 | 04:21 PM
BKbroiler's Avatar
BKbroiler
Do you push the brake duct back reaching thru the opening leading into the duct itself? If so then I see how that would work. So the duct just slips on to be reattached at the inlet point - where you stuck your hand thru?
Old Aug 29, 2009 | 04:31 PM
David426's Avatar
David426
I got my 10 year old niece to do it. Kids can get their little arms and hands in and out of there with little effort
Old Aug 29, 2009 | 08:11 PM
TEXHAWK0's Avatar
TEXHAWK0
For future reference, there is an access panel behind the front air dam on each side. (below the bumper) You only have to remove 6 or 8 screws to remove it, and then there is enough room to change bulbs and remove the whole side lamp housing if you want to.
Plus the bulbs don't have to be on, like with the headlights up, so they are cool and you don't burn your fingers.
Old Aug 29, 2009 | 09:32 PM
LoneStarFRC's Avatar
LoneStarFRC
That's the way I do it too. I just first mark the hood bumper screw for length before removing it, that way I put it back exactly where it was before so there's no adjustment hassles. Makes for lots of room for us guys with phat phorearms.
Old Aug 30, 2009 | 10:07 AM
vettenuts's Avatar
vettenuts
Yes, stick your fingers into the duct and push it back and down.
Old Aug 30, 2009 | 11:43 AM
BKbroiler's Avatar
BKbroiler
I'll have to try this method when the other side needs replacement. Thanks.
Old Aug 30, 2009 | 05:58 PM
lionelhutz's Avatar
lionelhutz
Could have tried a search;
http://forums.corvetteforum.com/c5-t...ng-lights.html
http://forums.corvetteforum.com/c5-t...rn-signal.html
http://forums.corvetteforum.com/c5-t...placement.html
This topic seems to continually comes up on the first page in C5 tech.
Peter
Old Aug 30, 2009 | 06:19 PM
LoneStarFRC
Peter
Ya think?
Old Aug 30, 2009 | 11:30 PM
lionelhutz's Avatar
lionelhutz
Originally Posted by LoneStarFRC
Ya think?
Yup, there was likely another thread about this with 5 replies about 3 below this one when it was started....
Peter
To How do you replace daytime running light bulb?
Old Aug 30, 2009 | 11:50 PM
jrose7004's Avatar
jrose7004
That's the best way.
Old Aug 31, 2009 | 07:25 AM
madskater5's Avatar
madskater5
that how i did it yesterday. takes like a minute.
madskater5's Avatar
madskater5
thats how i did this yesterday. very quick change.
