Z06 crossover pipe
Old Aug 29, 2009 | 10:57 PM
03sixspeed's Avatar
03sixspeed
Default Z06 crossover pipe
Is the C5 Z06 crossover exhaust pipe titanium also. If it is how much weight savings over the standard C5 pipe.
Old Aug 30, 2009 | 12:04 AM
lucky131969's Avatar
lucky131969
cat back only..
Old Aug 30, 2009 | 12:05 AM
BanditDude's Avatar
BanditDude
Only the mufflers are Ti.
Old Aug 30, 2009 | 12:20 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
From what I've heard the pipes are Ti as well. That's why people get upset when somebody cuts them off the car because welding them is an art.
Old Aug 30, 2009 | 08:00 AM
Rob's 73's Avatar
Rob's 73
It's the catback only. The center section is very heavy. Some people cut the Titanium over the axle pipe because one side is a real PITA to get out. You need the car at least 3 feet off the ground.
Old Aug 30, 2009 | 09:47 AM
DsC5's Avatar
DsC5
Old Aug 30, 2009 | 11:48 AM
bumble-z's Avatar
bumble-z
Default Butcher Man Cometh!
The reason some get upset when hearing others cutting off the pipes of a Ti cat back system, is because the individual doing the cutting is either#1 Too cheap to take and pay for some one to unbolt and remove properly. #2 Too lazy or do not have the proper equipment to do the job safely , hence they cut them to get them out.#3 There really isn't a need to butcher a decent, costly set of Ti catbacks, to get them off. When all said and done however, to each their own. Every one's different and thats what makes the world go around, and that is a good thing!.
Old Aug 30, 2009 | 01:03 PM
jrose7004's Avatar
jrose7004
The C5 ZO6 doesn't have a X-Pipe, it has a H-Pipe.
To Z06 crossover pipe
