Adjustable rocker arms
Old Aug 30, 2009 | 12:55 PM
lucky131969's Avatar
lucky131969
Default Adjustable rocker arms
I still have not seen a single post on a performance increase associated with using adjustable rocker arms. For those that run them, exactly what benefit have you realized ?
Old Aug 30, 2009 | 01:11 PM
TurboBerserker's Avatar
TurboBerserker
It's a hard question Lucky -- most of them are not a straight-up comparison to stockers. For example, Crane race gold 1.7 arms are actually 1.75:1 ratio and have "accelerated lift". The real benefit in adujstible arms IMO is the ability to adjust the valves rather having to guess at preload, etc. Performance-wise the better pieces (without the other stuff) might be worth 3-5hp (just guessing).
Due to the design of the stock rockers, I do, however, think everyone benefits from aftermarket rockers, based on seeing what happens when the stockers impode (needle bearings in you ears...). It's not a big enough deal that everyone should run right out and do it, but if you are doing a cam and springs anyway...
In that case, IMO, spend the few extra bills and get adjustibles. We're not talking shaft mounted billet Jesels here -- $700. The extra money means a dead nuts valve train, and the other performance benes -- accelerated ramp rates, bigger ratios, whatever.
Old Aug 30, 2009 | 01:18 PM
vettenuts's Avatar
vettenuts
The main advantage I see in adjustable rockers is when running something like Comp R lifters, that have a very narrow and precise preload requirement or when running a solid setup.
Old Oct 2, 2009 | 02:55 PM
Fartpipe's Avatar
Fartpipe
Try them out for yourself and report back with your results
Old Oct 2, 2009 | 06:49 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Usually only needed with solid roller setups.
But for anyone else, I suppose the benefit would be not needing to alter pushrod length to get lifter preload set correctly.
Old Oct 2, 2009 | 09:12 PM
vettenuts's Avatar
vettenuts
Its kind of a mixed bag, at least with stud mounted, because the pushrod also sets geometry so both need to be examined together.
To Adjustable rocker arms
