Which bulb for T84 Headlamp
Old Aug 30, 2009 | 03:07 PM
Drug Delivery's Avatar
Drug Delivery
Default Which bulb for T84 Headlamp
Well, apparently my headlamps were converted to the T84 export. No wonder I thought the wiring was a bit odd. Anyway, which bulb and wattage do I need for replacement? I think its the H4 halogen bulb but I'm not sure.
Old Aug 30, 2009 | 03:39 PM
cliff_ford's Avatar
cliff_ford
H4 is the one.
Old Aug 31, 2009 | 08:10 PM
Drug Delivery
I replaced the bulb and still no light. The passenger side works fine, both low and high beams. Anything else I should be looking for? The wiring looks intact all the way around. Any "extra" fuses with this set-up I might have to replace?
One other thing. The bulb I took out has this information on it: 12V 100/90W not for use in Europe G2
I'm not sure if this bulb is different than the standard H4 you can buy at any auto parts store.
After looking around on the web my wiring looks a bit different than the standard LAPD harness set-up. There are also two "fuse like" squares with three prongs that are in the wiring. These prongs that look similar to the prongs on the headlight itself.
Old Aug 31, 2009 | 11:39 PM
byronhunter's Avatar
byronhunter
The picture shows the relays required for higher wattage bulbs. Might try switching them. If that dosn't change anything, probably a wireing problem. Time for some troubleshooting with the Volt Meter.
Old Sep 1, 2009 | 10:27 PM
Drug Delivery
Switched the relays and the passenger side still works. All wiring looks in tact but who knows. I don't have a volt meter so further investigation will have to wait.
To Which bulb for T84 Headlamp
